W8 PerformanceForge Motorsport
    Nov 2011
    Post Thanks / Like
    2005 A6 Aircon problems
    Quick query in case anyone can shed any light on this.
    Bought an A6 3.0tdi today, and seller had explained a problem with the aircon, which I'm okay with, but wondered if anyone had come across something similar before the dealer charges me an arm and a leg just to trace the fault!
    Irrespective of where the temperature is set at on the control box all the vents, bar the middle two, which I've set for cooler air, pump out very hot air. If you turn the temp up to Hi then turn it back down again it works for a while then just builds back up again.
    Sounds to me like a valve or a sensor has failed and just letting the car keep pumping hot air in, but thought I'd check before spending a fortune getting to the bottom of it.
    Thanks for any advice.
    Don
    Jul 2007
    490
    Post Thanks / Like
    Is this with the aircon on or off?If its on can you check that the pipes from the compressor are cold?If OK then I guess the control flaps in the dash board have a fault.Is the grill over the sensor in the control unit clear?
    May 2006
    UK
    156
    Post Thanks / Like
    I have had my car a year, same model and it has done this twice, the air is mega hot!!, If I mess with the temp, up and down, on and off it sorts itself out. I would play around with it 1st as a dealer will just change a part for the sake of it.
    3.0 TDI S Line Quattro Avant, Leather, Bose, Colour MMI Sat Nav, Phone, LED rear + Xenons
    May 2010
    cleveland
    292
    Post Thanks / Like
    id say check the cabin temp sensor wherever thats located first.
    then is their a sensor in the heater airflow ducts too.
    pollen filter too perhaps??
    283bhp & 565nm =
    Oct 2008
    42
    Post Thanks / Like
  1. Audi A4 2005 - Multitronic Gearbox Problems.
    By Ash4d in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th August 2010, 13:35
  2. still aircon problems
    By simon.m in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd June 2010, 20:36
  3. Aircon problems
    By Cyrix in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th May 2010, 22:05
  4. Aircon problems
    By Carpy25 in forum General Technical / How To
    Last Post: 10th June 2008, 23:15
  5. 2005 2.0tdi tranny problems
    By Phantom_A4 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 26th September 2007, 15:55
