JuicyJBS
    Dec 2008
    17
    Post Thanks / Like
    AKE 2.5 tdi fault code 550
    My allroad has a nasty hesitation. 2.5tdi ake engine. 200k. The fault code that keeps coming back is 550 'start of injection regulation, value above upper control limit'
    This points to a fault in the injection pump, but I replaced that new about 20k ago, a suggestion is the needle lift sensor (part of injector #3)
    Has anyone played this game before?
    Jul 2007
    London
    1,572
    Post Thanks / Like
    Who adjusted the timing ? Usually the pump timing slips a little or the belt stretches so it goes out of the optimal timing window... Where abouts are you based ?
    FOR SALE:
    Aug 2008
    Isle of Skye
    16
    Post Thanks / Like
    Hi adamss24, can I ask you a question about injection timing? I have VAGCOM and can check my timing on my AKE engine no problem, but if I want to adjust it can this be done without putting the front of the car in the service position? Thanks in advance,
    Angus
    Quote Originally Posted by adamss24 View Post
    Jul 2007
    London
    1,572
    Post Thanks / Like
    Hi mate, if you have vag com, select engine -> measuring blocks 04 -> switch to Basic Settings -> TDI Timing, then select the last engine from the drop down box (AFB/AKN/AKE/BAU/BDG/AYM,etc.) and see where the plotted line is. The coolant needs to be at 80 Celsius with the engine at iddle. If it's too retarded then slacken the 3 bolts from the right hand side sprocket and carefully turn the pump clockwise a few mm ! Then start the engine again and repeat the steps above to get the plotted line just above the middle line, close to the top line. Small adjustments make big difference !
    FOR SALE:
  6. Thanks skyegtb thanked for this post
    Likes skyegtb liked this post
  1. 2001 Allroad 2.5 TDI AKE engine code
    By danny_acs in forum A6/S6/Allroad forum (C5 & C6 Chassis)
    Last Post: 1st November 2011, 08:31
  2. Pd 170 tdi fault code help pleas
    By ash101 in forum VCDS (formerly VAG-COM) forum
    Last Post: 3rd April 2011, 20:14
  3. A4 2.5 TDI engine code AKE camshaft replacement help please
    By doc2000ad in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th September 2010, 04:06
  4. Replies: 0
    Last Post: 1st September 2010, 20:42
  5. FAULT CODE......A3 TDI 2.0 BKD
    By vw754 in forum VCDS (formerly VAG-COM) forum
    Last Post: 27th January 2010, 19:18
