Adrian S FluxDTUK
    Aug 2008
    Isle of Skye
    16
    Post Thanks / Like
    Cruise control not working - brake light switch to blame?
    Hello. I am a newowner of a 2001 Allroad 2.5tdi and other than the cruise control beinginoperational it seems to be just about a perfect car. I have been using my VAGCOM to check to seewhy the cruise control does not work and have tested all functions on the cruisestalk and the brake switch etc and everything seems fine. I have however had an intermittent (returning)fault in the ABS, but this is very infrequent:
    Address 03: ABS Brakes Labels: 8D0-907-389.lbl
    Part No: 4Z7 907389
    Component:ABS/ESP allrad D57
    Coding: 06355
    Shop #: WSC02325
    VCID:0912408F19A9
    1 Fault Found:
    18265 - Load Signal: Error Message from ECU
    P1857 -35-10 - - - Intermittent
    On 2 occasions in the last 1500 miles of driving the ABS,ESP and vehicle level lights started flashing while I was driving and my boostwas cut until I stopped the car and turned off / on. Am I right in thinking that that could be dueto a faulty brake light switch? Is theinoperational cruise control possibly linked to this as well? For info I have checked every fuse in thefuse box, all are good, and the brake lights certainly appear to workperfectly, so I am a little stumped.
    I found some info elsewhere on the web about early A6cruise control modules developing dry joints in the solder. I have not checked my cruise module yet, butis this a know issue with the Allroad?
    Looking for any advice, thanks, Angus
    kite's Avatar
    Oct 2007
    East Berks
    469
    Post Thanks / Like
    if the car has a manual box , it could be the clutch switch
    A4 (b6) 2.5 TDi QS Saloon.
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,084
    Post Thanks / Like
    Wont be the brake switch as if this was faulty the brake light would be permentantly on.
    Could possibly be the clutch switch, though I also suspect the ABS fault could well be preventing the CC system from working.
    Audi A3 2.0TFSI S Line SE DSG
    Cruise Control | Ambient Lights | LED Lighting | Full Leather | RNS-E MK2
    OEM Bluetooth | AUX | CH/LH Lights | MFSW | S3 Pedals | BFT Remap
    JMB Retrofits - North East Retrofit Company
    Aug 2008
    Isle of Skye
    16
    Post Thanks / Like
    OK, that's what I'm starting to think myself. I will keep monitoring the situation but I suppose a new ABS module will be on the cards for the future....
    Quote Originally Posted by jb0o View Post
  1. Cruise control not working!!
    By SL11 CKK in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th September 2011, 22:53
  2. Clutch switch and cruise control
    By Welly in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th March 2010, 12:47
  3. Cruise Control not working?
    By JCsS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th November 2009, 17:20
  4. Cruise control not working
    By BILKO1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd November 2009, 16:38
  5. Cruise control not working
    By gidimille in forum General Technical / How To
    Last Post: 7th December 2005, 18:32
