UnicornDTUK
Results 1 to 21 of 21
    May 2006
    UK
    156
    Post Thanks / Like
    A6 C6 2006 3.0 TDI injectors need changing - advice please!!!
    Well took car to garage today and 3 of the injectors are no good, they have said I should do all 6 which is what most people say. I have been quoted £2000 to do fitted which is way more than I can afford but seems like a fair price compared to other stories. I have even tried to see if I can recondition but apparently with the piezo injectors this is not possible. I'm thinking even of ebay and 2nd hand, maybe ringing some salvage places. Has anybody else had this happen or any ideas???? Thanks as I'm thinking I may have to sell my car unless I can work out a cheaper solution.
    3.0 TDI S Line Quattro Avant, Leather, Bose, Colour MMI Sat Nav, Phone, LED rear + Xenons
    fjtwelve's Avatar
    Jan 2006
    Falmouth, Cornwall
    747
    Post Thanks / Like
    I don't know where you are but try talking to dieselbob see Diesel Bob Tuning - Home man knows his stuff
    2001 A6 Avant 2.5TDi quattro Sport 180hp+TurboDynamics MD438 hybrid+Bosio Race683s+3" exhaust+Celtic Tuning remap= need another dyno run
    2004 A4 Avant 1.9TDi quattro Sport 130hp + Superchip
    1988 Yamaha FJ1200 120hp
    May 2006
    UK
    156
    Post Thanks / Like
    I've spent days on the internet and no further really so any suggestions greatly received. I will call him tomorrow. Thanks
    May 2010
    cleveland
    292
    Post Thanks / Like
    can you not soak them in injector cleaner? or get cleaned by ultrasonics?
    283bhp & 565nm =
    May 2006
    UK
    156
    Post Thanks / Like
    everybody says that you can not clean, once they are gone they are dead!! I have found them new on ebay and I even have found 6 second hand but they want nearly £500.00 and they are the same part number as what is in the car so they are 5 years old....not really worth the risk! The part number has now been upgraded a few times as bosch change them. Has no one else had injector issues??
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,877
    Post Thanks / Like
    my warranty guy at Audi in convo about the 170's injector issues told me the 3.0 didn't suffer from the same problem at all and it was the best engine in his opinion, that Audi did...... sounds like your unlucky as your the first i've seen since researching
    Xbox 360 gamer ID : Timffy
    2000 Blue Astra 1.8 SXi - Sold
    1996 Burgundy (yup!) Escort 1.6 LX - Sold
    1990 Red Rover 214S - Sold
    May 2006
    UK
    156
    Post Thanks / Like
    defo not the case, yes to great engine, pulls like a train and great mpg but the injectors have a problem. The BMK engine code has already had its injector part number changed about 4 times. If you search the forums it comes up quite alot!! I had white smoke at tick over so searched the forums and knew my issue before I even went to the garage. Unfortunately the garage confirmed the expensive problem.
    May 2010
    cleveland
    292
    Post Thanks / Like
    are their any better injectors that you found or did they cure it later on?
    283bhp & 565nm =
    882
    Post Thanks / Like
    If would go for the 6 @£500 at least that will give you spares are you able to swap them yourself?
    May 2006
    UK
    156
    Post Thanks / Like
    the injectors are improved as Bosch learn from their mistakes, we are basically doing the R and D on the road. To be fair the injector does an amazing job and they can test them but there's nothing like 5 years and 80000 to really test them. Audi have changed the part number I think 4 times so each time an improvement i guess. My problem is the 2nd hand ones are the same part number therefore I'm not going to take the risk as the garage can tell me nothing about the mileage of car they came out of and its £200.00 to fit. Not able to fit myself as they need to be coded to the ECU. Still searching the internet for 2nd hand but newer part numbers WITH history. The part numbers in date order of oldest 1st is 059 130 277 AB, 059 130 277 BA, 059 130 277 AH and latest is 059 130 277 BD or 059 130 277 AX when you exchange them.
    May 2010
    cleveland
    292
    Post Thanks / Like
    do you have the dates they changed each time to the newer ones?
    283bhp & 565nm =
    882
    Post Thanks / Like
    Fair enough, if you were able to change yourself then no problem, if you have to get the garage to do the job then you could be just chucking good money away. Good luck on the search
    May 2006
    UK
    156
    Post Thanks / Like
    Not sure on the dates they were changed. The car still drives, its just at tick over its an issue. Hopefully I'll find some soon.
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,877
    Post Thanks / Like
    can these be coded via vagcom?
    May 2006
    UK
    156
    Post Thanks / Like
    not sure, I may have found some second hand and I'm going to let my garage do the coding if any??
    882
    Post Thanks / Like
    There is no mention of any coding require for injector replacment.
    http://wiki.ross-tech.com/wiki/index...I_(BKS/BMK/BUN)
    Ross-Tech: VCDS: Diagnostic Procedures
    May 2006
    UK
    156
    Post Thanks / Like
    are you saying instal myself? Maybe worth a try but not sure? The garage only said to me that I MUST by the right ones and that not ALL injectors will fit. I have certainly found that even for the 3.0 TDI there are a few engine codes and they are not all the same.
  19. Thanks laichzeit thanked for this post
  20. #18
    May 2006
    UK
    156
    Post Thanks / Like
    FOUND SOME!!! with the latest code, arrived this morning and garage has put them in. All seems good so far!!! Took ages on ebay ringing loads of people but cost £700.00 all in FITTED!
  21. #19
    May 2006
    UK
    156
    Post Thanks / Like
    I don't want to jinx it but car still good, I think success!!! I think I was lucky to find the injectors I did as I'm sure some breakers would sell you anything so I'm not saying it will always work but I'm a happy bunny.
  22. #20
    Apr 2012
    Post Thanks / Like
    I am having extactly the same experience as you have had with your injectors crispin. Audi told me that, on my 2006 A6 3.0TDI Avant Engine code : BMK Two of the injectors are faulty and recommend replacing all of them. The quoted repair costs amounted 64 000 ZAR (thats around 5000pounds) which is offcourse too much for me. I have traced down a new set of injectors on e-bay (059130277BD)
    What i would like to know from you is, DID the injectors have to be coded to the ECU or not?
    I would like to do this myself.
    Your response would be highly appreciated
    Regards,
    Laichzeit
  23. #21
    May 2006
    UK
    156
    Post Thanks / Like
    Hi, sorry to hear you are having same issue, Audi should help more as there is a issue with these injectors, I did loads of research and was lucky in finding latest code 2nd hand. The injectors did have to be coded and my local garage over the road fitted them for £100.00, I don't think its a hard job, what part of the UK are you in, my guy is very helpful and he is in TW8 in West London.
  1. Anyone else with this problem on 2006 2.0 TDi? Injectors...
    By jfarhead in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3 Weeks Ago, 08:29
  2. Injectors failed, your advice please...
    By nin in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th October 2010, 13:50
  3. 2006 3l TDI A4 avant, noisy engine = injectors?
    By JD09 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 16th September 2010, 15:07
  4. Changing Rear Brake Pads 2006 A6..........
    By A6Ian in forum A6/S6/Allroad forum (C5 & C6 Chassis)
    Last Post: 28th January 2010, 14:59
  5. Changing S3 210 injectors to 225 injectors
    By brucelee1973 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th April 2007, 17:46
