Badger5Chris Nott
Results 1 to 16 of 16
    LawrieV6Quattro's Avatar
    Jul 2013
    29
    3.0 TDi...what next?
    Hey guys, not been posting a lot, well, at all!
    I have a 3.0 TDi Quattro. DPF delete and straight through exhaust (sounds nuts) and custom map. Estimated running at 300bhp but not had it on the dyno yet. Next on my list is an intercooler and working towards a hybrid turbo & high pressure fuel pump next summer.
    Can anyone recommend any other upgrades that would be recommended as supporting mods towards the hybrid? Obviously the clutch will need done.
    Nov 2013
    Heath Hayes
    951
    Have you upgraded the brakes ?.
    As far as I can see the DPF thing is only a visual check, If you have had yours gutted you should be good. If it's been replaced with a pipe then hopefully you kept the original DPF.
    I am going down the same road as yourself, currently sorted a brake upgrade, improved the exhaust, will be sorting an intercooler upgrade next then a map and remove the DPF.
    I think 300bhp will be enough for me.
    Karl.
    Karls 312bhp A4 3.0 TDI build thread http://www.audi-sport.net/vb/audi-s4...ld-thread.html
    Jul 2013
    29
    Quote Originally Posted by desertstorm View Post
    Karl.
    It's the delete pipe from darkside developments but I have a friendly MOT tester so not worried about it failing I've been looking at the 6 pot upgrade from D2 brakes but they certainly aren't cheap! What upgrade did you do Karl?
    Nov 2013
    Heath Hayes
    951
    I upgraded the brakes to the S4 spec. Bought a complete set of brakes off an S5. They are 345 x30 vented at the front and 330 x 22 vented at the rear. They use the same calipers as my car car has already but they are painted black from the factory. The main difference is the caliper carriers which move the calipers out to accommodate the larger discs.
    In my opinion this is more than good enough for street use, The larger 6 pot systems are good if you are going to be doing track days but really wasted on the road.
    Click on the link to my build thread in my signature.
    karl.
    Jamie-S's Avatar
    Jun 2013
    Coventry
    279
    Good look finding a clutch for one of these
    did you get a custom exhaust? Sound clip?
    Jul 2013
    29
    Quote Originally Posted by Jamie-S View Post
    I'll upload a video to YouTube and link it on here tonight, went with the Darkside developments DPF delete and had the rear silencers removed with over sized round tips...the standard exhaust is actually very well designed (once you remove the silencers which are very restrictive!)
    I'm pretty sure Darkside sell a clutch, if they don't then they will do soon as they now have a 3.0 tdi A4 as a development car :D
    Jamie-S's Avatar
    Jun 2013
    Coventry
    279
    Quote Originally Posted by LawrieV6Quattro View Post
    I'm sure they get there's from vw, I don't want to pay that price. apparently luk are distributing them end of January to resellers and desert storm found it for 200 quid.
    Look forward to the vid...
    Jul 2013
    29
    Since the remap the flywheels been juddering, not sure if it's always been there or if it's down to the extra torque, must be putting out around 450lb/ft
    Jamie-S's Avatar
    Jun 2013
    Coventry
    279
    Who did you map and how much if you don't mind me asking?
    Mines juddering now ever so slightly and I want a remap but I'm not going to get it done until i've got a new clutch and fly. I have already got the flywheel though cheapest is 300 from buypartsby
    Jul 2013
    29
    [Q UOTE=Jamie-S;2037158]Who did you map and how much if you don't mind me asking?
    Mines juddering now ever so slightly and I want a remap but I'm not going to get it done until i've got a new clutch and fly. I have already got the flywheel though cheapest is 300 from buypartsby[/QUOTE]
    Ecotune in Glasgow I got a "special" price though. Fully custom software as well! They're in the process of installing a 4WD rolling road so still don't know what it putting out.
    The flywheel on mine judders mainly when it's cold but the clutch has never slipped on hard acceleration so I'm not too fussed about replacing anything straight away. Maybe do it just before the hybrid goes on
    Jamie-S's Avatar
    Jun 2013
    Coventry
    279
    Mines never slipped either but that slight bit of judder annoys me, but its very minor most probably wouldnt even feel it.
    Until i can find someone supplying a clutch for reasonable money ie not coming from vw i'll have to just wait
    Jan 2011
    South Lanarkshire
    15
    Look forward to hearing it and seeing what power is after watch this http://m.youtube.com/watch?v=0p9hTyO...%3D0p9hTyOqxuw
    Ivo
    Jun 2009
    27
    What hybrid are you going to use?
    I am looking for an upgrade turbo of a friend's Touareg 3.0TDI and right now we are deciding betweend darkside GTB2566 or Loba LO350 hybrid for 3.0TDI.
    Jul 2013
    29
    Definitely the Darkside kit mate
    Nov 2013
    Heath Hayes
    951
    The Loba kit is good but expensive 2600 euros. Darkside is more realistic at £1600 . Darkside will also send away your own turbo to be modified but I think that takes a while
    karl
    Jul 2013
    29
    I've got a local tuner who will hybrid my turbo and give me a loan of one while it's being done. I quite fancy buying a whole new unit anyway though to keep my old one as a spare
