Volks AutosEM Tuning
    Jun 2013
    155
    Help with new wheels for A5 Sportback
    Looking to upgrade the wheels on my S-Line Sportback.
    They are the S-Line 18inch wheels and previously had an A3 Black Edition with the titanium rotor wheels. I was considering the equivalent for this car, but seen some nice 20 inch wheels from Rs5's etc on fleebay. Can anyone help explain what the ideal ET is for my car, and what a bigger or smaller ET does as well as what the lower profile wheels will do to the handling? I have a 3.0TDI FWD at the moment and the current set up is good, even if the traction control kicks in when accelerating each time and torque steer is very bad.
    Jun 2013
    155
    I have just found out i have "sports suspension" and not the "S-Line suspension". S-Line suspension lowers the car 30mm - does anyone know how much lowered the sports Suspension is? and how easy it is to change the suspension?
    Jun 2013
    155
    OK, thanks for the help, ive worked out that sports suspension is 20mm lower, and s-line another 10mm.
    I've worked out the 33ET is what i have and the 24ET I'm looking at will make my wheels stick out another 9mm. is there anyway to reduce this and would this affect the drive?
    Blackie's Avatar
    Feb 2004
    In a house
    634
    Rs5 rotors will fit very nicely.
    You may even still want spacers if you want a better stance but try the wheels first & se how you get on
    My A5 has 19 Y spokes with 25mm rear & 20mm front spacers
    Nov 2010
    11
    Quote Originally Posted by Blackie View Post
    Correct
    I am running those RS5 20 inch rotors with a 5mm spacer. They are just perfect for the sportback as I ave no rubbing and I am on coilovers so will be lower than you.
    SB
  1. Help with tyre sizes for staggered wheels!!
    By Tom Mineral Grey S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st October 2009, 00:39
  2. Which wheels for my sportback?
    By koen_dr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st January 2006, 17:40
  3. New Wheels for A3 2.0 TDI
    By morgado in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th January 2005, 19:11
  4. New Wheels for new A3
    By morgado in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th January 2005, 19:04
  5. a new wheel for my A3
    By Khufu in forum General Chat
    Last Post: 4th December 2003, 13:37
Tags for this Thread
