Results 1 to 15 of 15
    Mar 2013
    Audi A5 rear cluster LED change
    Hi,
    Is there anyone out there that knows much about changing pre 2009 standard rear clusters to newer led clusters?
    I have fitted the led clusters in however the wiring plugs are different on both units ( led has more wires ) I was lead to believe that they were plug and play - with a bit of coding but I was wrong is there such thing as adapters, or wiring looms that convert these?
    has anyone done anything out there that has made it work? Or can anyone out there do it?
    kind Regards
    27,114
    Are yours the original A5 rear clusters or original led versions?
    You may need a new module & harness or someone to convert it, vcds or a dealer to adapt.
    I maybe able to do this for you.
    Mar 2013
    Hi,
    They are genuine Audi Led clusters. I can provide the part numbers if you wish?
    Kind Regards
    27,114
    I meant which version of clusters, as there were halogen, then led & now the newer led type iirc, yeah what's the part numbers?
    Mar 2013
    I'll get you the part number tomorrow, how ever for now I can confirm they are the LED clusters from late 2009-2012.
    Kind Regards
    Mar 2013
    Hi,
    The part number for one of them is 8T0 945 093A ( 19/11/10 ) version
    kind Regards
    Jun 2013
    12
    Hello,
    I want to do the same thing as you. Audi are charging £700 for the kit which includes the lights, module & harness. They will fit for £180. I don't think there is a cheaper way. I have rung a few places about coding the lights but think its a big job by the sounds of things and people not wanting to do it. If you have any luck then let me know. Mine is an 08 audi A5 3.0tdi
    thanks Lee
    May 2013
    30
    Jun 2013
    12
    I have sent them an email now. Great find, thanks
    Jun 2013
    12
    The company replied saying that the lights might still need coding so it would be cheaper buying them from audi for £700
    Mar 2013
    However Audi have said they will supply the retro kit, but not fit it in, as they wish not to take any chances of blowing anything else whilst s installing it.
    Helpful Audi as standard! NOT!!!
    Regards
    Jun 2013
    12
    Rajdaman69 - yeah thats right, i only found one Audi dealer that would supply and fit, the rest said they would supply but not fit. Not very helpful at all. Starting to think its more hastle than its worth trying to get these lights fitted. I should have just waited and gone for a 2010 model with the lights already installed
    Nov 2013
    61
    Have you sorted this issue?
    Quote Originally Posted by lee_w View Post
    Sorry, I know this is an old post but I've just joined the site and wondered if you have sorted this? PM me if not and I can point you in the right direction or may be able to help with the coding.
    Mar 2014
    Quote Originally Posted by RS5UK View Post
    Hi mate I'm changing my tail lights to led, was going to ask how much do u charge? thanks
    Jan 2014
    same here mate, i am interested too
  1. Audi A5 rear cluster change to led
    By Rajdaman69 in forum A5/S5/RS5 Forum
    Last Post: 6th May 2013, 08:04
  2. Audi A3 Rear LED Lights Sport Back
    By S4 SWO in forum For Sale/Wanted - Audi Parts
    Last Post: 1st November 2011, 22:21
  3. Audi Instrument Cluster LED bulbs
    By Greig300 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th April 2011, 20:08
  4. Audi S4 Rear LED
    By Nez in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th August 2010, 04:07
  5. Facelift (08/09) Audi A3/S3 rear clusters
    By S3IZZO in forum Parts Requests
    Last Post: 10th July 2008, 11:15
