Chris NottEM Tuning
Results 1 to 7 of 7
    Sep 2010
    Ireland
    66
    MMI Updating - Remap issues
    Hi Guys,
    Going to update my MMI software to 5570 but heard that it can wipe any engine ECU remap you might have! Can anyone confirm if this is true or not. I find it hard to believe but want to make sure!
    Cheers,
    Finn
    27,031
    I always find it wise, unless told otherwise, when updating firmware to either have engine running or a battery regulator attached, to maintain power levels as some systems shut down & send comms messages that can interfere with update processes, I don't know this update specifically, but does it have 3 discs, as I seem to recall 1 update takes a while & some people have had to login & re-enable some systems, as for remaps, I don't know any mmi update that rewrites the engine map.
    Sep 2010
    Ireland
    66
    Ye ive read you need to leave it on charge or running. Will have to source a car charger from somewhere I guess. Thanks for the info. I thought it sounded crazy that it would rewrite the ECU!
    Hopefully it all goes smoothly. Just downloading the updates at the moment,
    27,031
    Be very careful using downloads for mmi, as if they're corrupted you could end up with a bigger expensive problem, verify the data being used.
    Sep 2010
    Ireland
    66
    How can I verify it? Ive got it off a GPS Underground site and other guys on there sound as if its worked for them. Thought it would refuse it if it was corrupt coding etc
    27,031
    That's what I meant, verify the download via other users.
    Sep 2010
    Ireland
    66
    Ah ye ok will do, cheers
  1. Help!! MMI Update
    By razputin in forum In-Car Entertainment
    Last Post: 19th October 2009, 10:37
  2. Facelift S3 remap issues?
    By crazylegscrane in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th May 2009, 11:18
  3. B5 S4 Remap Issues
    By S4SIMON in forum Tuning
    Last Post: 8th April 2008, 08:48
  4. Remap issues!
    By NoggyDS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th March 2008, 18:42
  5. B5 S4 Remap Issues
    By S4SIMON in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th February 2008, 18:43
