    Laz
    Laz's Avatar
    Mar 2013
    31
    Rear wheels making a 'hum-hum-hum' sound?
    Had the family in the car earlier and noticed there was a humming sound coming from the rear wheels. Doesn't seem to appear evident when I'm on my own, just with passengers in the back. It's not unbearable but it is noticeable. I'm guessing it's the wheel bearings, or wheel alignment?
    What am I looking at with wheel bearing costs from Audi? Is that by any chance included in a Geometric check (wheel alignment) that Audi do?
    Blackie's Avatar
    Feb 2004
    In a house
    634
    Check the tyres . Just changed one of mine as it had "staggered" in a castle turret manner on the inside. Sounds like a wheel bearing but isnt
    its all nice and quiet again now
    Laz
    Laz's Avatar
    Mar 2013
    31
    Tyres are fine mate, besides their tread which is a tad low. Three of them are on 3mm while the back left is on 6mm.
    I'm not too worried about that. Another thing I have noticed which is worrying me though is when I reverse out my drive and turn, the wheels almost sound like there's some sort of cranking/creaking noise as if there's something wrong with the front suspensions.
    I generally don't have these problems when I've been running the car for a while and then come back a little later. It's more often when the car is cold. Will probably go down to the Audi garage and get them to have a look.
    JimC64's Avatar
    Apr 2009
    Glasgow UK
    242
    Wheel bearings could be possible....just had Audi quote £293 for a front
    Audi Technk doing it tomorrow for £190
    Could also be "Sawtooth" effect on the tyres as mentioned?
    The tread may be fine but its the way that they have worn.....do a check maybe?
    I had a type of grinding / rubbing noise from my fronts.......turned out to be the backplate hitting against the brake disc at times and easily resolved.
    MY2008 (58) XJ X358 2.7 Tdvi Sovereign LWB remapped to 245bhp, Black, Ivory leather interior with black piping, 20" Alloys
    MY2007 Audi A6 2.0 Tdi SE
    176bhp Stratos Blue, badged as 3.0 Tdi Quattro.Front & Rear park assist,Comms Pack High,Sline grille badge added, 19" RS4 alloys,Rear tints,Dipped bulbs 80W,Mainbeams & Foglights 100W,Number plate LED's,Interior LED's,First Aid Kit,Bootliner,Mudflaps front & rear,Calipers & hubs painted
    Laz
    Laz's Avatar
    Mar 2013
    31
    Wow, I thought it'd cost around 150. Hope it's not, in that case.
    Interesting you bring up the grinding noise. I had that once when reversing out. My front right brake disk has these black circles. Could that be the thing you've mentioned?
    It's only the front right. The others are all clean.
  1. metal on metal sound and rear wheel wobble
    By ScoobyA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th April 2007, 00:36
  2. Noise from rear wheel - Tyre problem ? Help
    By imported_Smudge973 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th February 2007, 19:22
  3. Rear wheel drive Audis?
    By jungle in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd February 2005, 08:25
  4. Rear wheel vibration on full lock
    By h3msy in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th December 2004, 23:09
  5. Should Audis have rear wheel drive?
    By imported_ndrummond in forum Handling
    Last Post: 30th September 2004, 13:09
