Front fogs replaced with Ice white bulbs.
Hey,
I just ordered some of these. Is there a straight forward approach to getting access to the fog light bulbs?
Thanks in advance.
Very easy to fit, if you are careful getting the plastic grills off.
Hey,
Thanks in advance.
Straight forward Dale - there's a cover behind each bulb in the wheel arch, turn the wheel into the arch, remove the 3 torx screws holding in the inner arch liner, pull it back, press the tab to release the bulb connector, twist the bulb holder and out pops the bulb, replace with the new 'white' bulbs - guide here if you can access it buddy, 5 mins each side!! DIY Mod A5 Front Fog Lights Install - for newbies - A5_OC
Reactions: Steve77
11
4K
S3IZZO
S
580
9
2K
