JMB RetrofitsSky Insurance
Results 1 to 14 of 14
    Laz
    Laz's Avatar
    Mar 2013
    31
    How to remove the Anti-glare from the MMI screen?
    Had the car a few weeks now and not sure if I ended up doing it or if it was already there, but the anti-glare layer is messed up. It's not too appealing and I wanted to know if anyone has used anything to remove it?
    I can't take the screen out so I'll have to do it as is. I heard abrasive products shouldn't be used for obvious reasons so if anyone can point something that'll take it off nicely without damaging the screen, that would be appreciated.
    27,089
    I use Plast-RX on the rns-e screens if a clients scratched there's, takes a while & you will need to remove the screen to do it properly, its a fairly simple task to remove from console.
    Buy Meguiar's Plast-RX from Meguiar's UK
    Laz
    Laz's Avatar
    Mar 2013
    31
    I rather not attempt taking it off. I would rather just use cotton buds in the sides and corners. I heard Displex works but looking at what they (Displex) say under their video on the comments, they don't recommend it for LCD's.
    Do you have any pictures of how it looks after with what you use, NHN?
    27,089
    It looks perfectly fine afterwards & no pics I'm afraid, you expect it to be really reflective afterwards but its not IMHO.
    You would be best to remove screen & do tbh as it requires some genie in a bottle rubbing for sure lol.
    Laz
    Laz's Avatar
    Mar 2013
    31
    Ordered the stuff. A little worried, though. It says not to use it on LCD's or Navigation screens.
    The fate of my screen is resting on your reccomendation, NHN! Lol!
    Feb 2013
    Hampshire
    62
    Laz, I look forward to hearing about your results. I'm considering a similar project. I've been reading around about various methods to remove the anti glare coating but many seem a bit scary like using Brasso. I'm thinking about using this product http://www.amazon.co.uk/Vikuiti-scre.../dp/B0076YP6BQ to try and make up for the removed layer.
    Laz
    Laz's Avatar
    Mar 2013
    31
    I just did it a few hours ago, Stone!
    Like yourself, I was worried as this product is not advised to be used on LCD's or navigational screens, but anyway, I received it today and what can I say.... it looks absolutely brilliant. I actually really like the look of it now. The screen colours look stronger and not shiny at all. I'm contemplating not putting anything on it.
    The stuff works great, without problems. At first when I dabbed it on and rubbed it didn't do anything and I was worried that these scratches are more extensive than just the anti-glare, but when I cleared it away, I noticed the anti-glare layer had a fade to it to the area I was rubbing and from there, it was just a matter of taking it all off. Honestly, it looks better than how it was before.
    It'll take you about 10-15 minutes to do it all. I didn't take the screen out of the housing and just did it while it was in. Didn't have any problems although getting the sides required me to use a cotton bud and even then, you won't get it completely like the rest of the screen until you keep the bud at it. BUT one thing I will advise you, try not to use a cotton bud because I did that for a little too long along the corners and it seemed to give it a stronger shine, almost like it started to take another layer off the anti-glare off and make it super shiny, but really, that was only because I was extensively rubbing with a cotton bud along the corners and even despite the slight shine in the corners because of my own mistake, it still looks great. For the corners, just try to use a cotton ball and put a bud on it for the corners so there's not a concentrated amount of pressure on the sides which may give you a stronger shine.
    I wish I had taken a before picture to show you because it looked unbearable. I'll take a picture of the after-look tomorrow and post it here for you to see.
    Another thing! If you don't plan to take it out the housing, then don't make another mistake I made which is not taping off the matt plastic surroundings as when you rub your micro-fiber cloth or cotton balls or whatever you may use, it also rubs against the matt plastic housing around it and since you're going to be rubbing for about 15 minutes, it will take it's toll and also give the surroundings a shiny look which you don't really want, so get some masking tape and do that just before you start. Otherwise, that's really it. Don't press all too hard as this won't come off with pressure, but with patience and continuous rubbing. Don't go for any other product, my man. This worked great. If you can take it out of the housing, then it will be much better for getting the corners nice and leveled with the rest of the cleaned screen.
    I bought the stuff 'Meguiars Plast-RX' from Ebay for £8.74. Will post pictures for you tomorrow, mate. It beats paying for a brand new screen any day of the week.
    27,089
    Glad my suggestion worked out for you
    Laz
    Laz's Avatar
    Mar 2013
    31
    Yeah, I actually just came on to thank you for the suggestion. I appreciate the help!
    Feb 2013
    Hampshire
    62
    Thanks Laz for your write up and Nigel for the original suggestion.
    Laz
    Laz's Avatar
    Mar 2013
    31
    Here's the pictures mate. Sorry I couldn't get any brighter ones. Flash on the phone wasn't working.
    Feb 2013
    Hampshire
    62
    Looks great.
    May 2009
    south yorkshire
    628
    hows screen quality in bright sunlight after this .
    27,089
    In all honesty, not bad at all, the rns is more open to the light than the full mmi systems, so would suffer more, but copes perfectly ok & not much difference than with antiglare still on, the mmi systems are sheltered to a degree from the light, so should be better than rns with & without antiglare.
  1. Cannot remove the quick coupling from the radiator bottom. A3, 2.0tdi
    By audio in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th January 2012, 22:28
  2. How To Remove Front Audi Rings From The Grill ?
    By Dazboss in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2011, 23:12
  3. HOW CAN YOUR MOTOR STAND OUT FROM THE CROWD WITH AUDI WHEELS?
    By vorsprung dork in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th February 2011, 10:40
  4. How easy is it to remove the audi rings from the front and back to spray black???
    By M22_PRE in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th February 2008, 10:07
  5. removing the bose sub from the a3 8p
    By khalil in forum In-Car Entertainment
    Last Post: 26th October 2006, 18:01
