    Laz
    Laz's Avatar
    Mar 2013
    31
    Adding an Oil Dipstick to an Audi A5?
    I've read about it on some forums and I don't like relying on the MMI. Just yesterday I had an oil light warning so I added 500ml of oil and also had a 'health inspection' from Audi the next day. They told me the car's oil was full, but I didn't see how that was possible since the light came up and I only added 500ml of oil. I got home and my oil level was reading 'ok', so really, either Audi mehanics don't know how to correctly read gauges or this MMI oil reading thing is a load of garbage.
    I wanted to know if it's possible to install one. I heard that this is the Oil Dipstick's number: '06J 115 611 E' but just wanted to clarify if you can and if it's the correct one. Also, I wanted to know if there's any UK sellers that may sell this part.
    Many thanks.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,525
    That's the number
    Get it from Audi or TPS
    Laz
    Laz's Avatar
    Mar 2013
    31
    Thanks Bez, going to order it from TPS. They quoted a price of £15 which sounds good.
    Nov 2005
    UK
    586
    I did this on my 2010 S4....well worth it.
    For your own piece of mind, just check that when you fit the dipstick and the MMI level says full, it reads as 'max' on the dipstick....then you just forget about the MMI and measure it the old fashioned way..
    Laz
    Laz's Avatar
    Mar 2013
    31
    Good stuff. Just wanted to confirm, TPS said that they don't think this part is for Audi A5's. Is it definitely the correct item number?
    Aug 2012
    Quote Originally Posted by Laz View Post
    This was the first hing I did on my A5, went to Audi and said I want a dipstick for a 2007 A5. They ordered it in and 3 days later I fitted it. Not sure of the part number now, but ask at Audi to confirm the number.
  1. oil leak injector seals audi a4 2.5 tdi v6
    By eliasuk98 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd March 2011, 22:29
  2. Oil & Filter Change At Audi
    By thelomondaudigroup in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th September 2010, 19:45
  3. Changing my oil dipstick help
    By dragonstyle in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2010, 09:19
  4. Oil dipstick guide..and water temp sensor
    By Custard in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th December 2009, 18:47
  5. Adding a Generic Amp to my Audi A4
    By AudiNick in forum General Technical / How To
    Last Post: 8th January 2007, 19:57
