Badger5Monster Motorsport
    Dec 2009
    Talking S5 not turning over
    Hi,
    Can someone help my S5 is not turning over, I went out to start this morning, it cranked for a second and since then the ignition comes on but absolutely no crank. The battery has 12.3 V across it at rest and so I suspect the starter motor, I would like to locate the starter motor to investigate, anyone know where it is located.? Or have any other ideas as to the prob cheers Ben
    riggssuzuki's Avatar
    Jan 2012
    Elgin, Scotland
    444
    Put your meter on the battery then turn on the lights. If it drops significantly then it is a battery issue.
    2011 A4 2.0 TFSI Quattro Dynamik. IBIS White.
    Dec 2009
    Quote Originally Posted by riggssuzuki View Post
    Car has had an 800Ah battery pack on it to test, and battery is fine. Its a 2008 S% and only done 46k miles, could the starter motor really be goosed and if so would audi look at good will since its not an item that you can abuse like a clutch, Thinking it may have been dodgy to begin with??
    Nov 2005
    UK
    586
    Don't really know much about these things, but there must be an isolator in the circuit which is why you have to have your foot on the clutch on a manual, and presumably have to do something like have it in Park on an automatic gearbox ? Maybe that could be on the blink ?
    Not sure how you would check for that, but maybe someone else on here can advise.
    alfiejts's Avatar
    Jul 2006
    Lytham St Annes
    352
    More likely too be something minor such as an one of the switches that feed into the engine management software.
    My 2012 A5's start and stop system has been playing up and on a couple of occasions, I also got no response when I pressed my key to start the engine.
    They traced the issue to a faulty switch on the gearbox (that presumably told the car when it was in neutral...)
    Could be something similar on yours. There's always the chance its the starter motor, but more likely a smaller component in the chain....
    Not sure how you'd find out without proper diagnostic tools though...
    Not like the old days when you could just follow the electrical circuit from battery to starter motor...
    2012 White A5 Coupe TFSi Black Edition
    (Was 2004 A3 2.0 TDi S-Line DSG, owned from 2005 to 2012....)
  1. AGU not turning over
    By kennymeechan in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd April 2012, 13:33
  2. Help ! 2007 b7 a4 tdi 170....engine will not turn over
    By vw754 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 11th August 2011, 19:54
  3. A3 1.8t AGU engine ... car turns over but will not start. HELP
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd October 2010, 14:53
  4. car will not turn over
    By hammondr in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th June 2009, 23:48
  5. Audi turning over but not starting.
    By K7ERG in forum Diesel forum
    Last Post: 26th January 2007, 09:02
