EM TuningAH Fabrications
Results 1 to 8 of 8
    Sep 2012
    Rs5 steering wheel airbag
    Hi guys just wondering of anyone has got the code for the airbag of the 2012 rs5 steering wheel. I e got an a1 185 and I'm looking to put the flat bottom rs5 wheel in it but do a straight swap with the airbag as it looks an identical fit. All help is greatly appreciated
    Best regards
    Ian
    26,774
    Ok on an A3 8P I had to custom wire the airbag loom, so you may need the same if airbag connections arent the same as yours.
    Show me your current wheel & airbag, assume you've taken yours of already to look at, so underside of airbag would be good.
    Sep 2012
    Okay mate here is my steering wheel
    I haven't taken mine off because I don't know how to buy I've seen one off the wheel however I didn't think of looking at finding the code! *doh!* I've got the code for the 2012 a1 steering wheel airbag which I assume is the same?!
    Regards
    Ian
    Sep 2012
    I forgot to mention mine doesn't have the paddles which is why I want the steering wheel, can they be coded or made useable in any way, I hope so!
    26,774
    Yes can be coded for paddles to work, as long s its stronic & not manual lol.
    Looks like same airbag to me, subject to confirmation on fitting, but the 2 share "some" codes.
    Do you need it fitting for you?
    Sep 2012
    Lol yes it's a tronic mate. I have the airbag code for the my 2012 a1 if that helps? I think I'll buy it then but yes I will need it fitting mate.How much are they to fit ect ect. Thanks mate
    26,774
    I will reply to your pm with my number, then you can ring me to get fitted
    Sep 2012
    Okay Nigel nice one Mate
  1. Audi A3 8P: Steering wheel, airbag, double din setup and indicator stalk
    By Shane. in forum For Sale/Wanted - Audi Parts
    Last Post: 13th May 2011, 01:33
  2. Posting a Steering Wheel & Airbag
    By JohnboyC in forum General Chat
    Last Post: 31st January 2010, 17:39
  3. Replies: 2
    Last Post: 18th August 2009, 10:25
  4. Steering Wheel/Airbag
    By celly in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th September 2007, 21:54
  5. Custom steering wheel & Airbag light...
    By jbw in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd March 2005, 12:38
