JuicyVAG Check
    Scruffy's Avatar
    Feb 2009
    Leeds
    61
    Post Thanks / Like
    Start button - hard to the floor clutch pedal problem
    Anyone know how to adjust the point where my S5 will start up. I'm having to almost put the pedal through the floor of the car to get it to work!
    Thanks people
    Audi S5 4.2 V8 fully loaded in phantom black and lush red seats!
    Be Gentle
    Sep 2010
    Kent, United Kingdom
    116
    Post Thanks / Like
    Hm that's weird. Must say though I'm pretty sure I press my clutch all the way to the floor when I start it up, so I'll take a look tomorrow and see if there's any leeway with it.
    Assuming this is a cross-model issue of course, I don't have an S5
    Currently Driving: Phantom Black 2011 Audi A5 S-Line Black Edition 2.0L TDi 210bhp 420Nm
    Apr 2010
    49
    Post Thanks / Like
    I had that experience in a 2.0 TFSI Cab that had as courtesy for a week - took me ages to get it started and ended up pulling the seat forward and had to almost bury the clutch pedal in the floor (only done £2k miles as well!).
    TimJK's Avatar
    May 2011
    Norwich, Norfolk, United Kingdom
    286
    Post Thanks / Like
    had this prob, realised my foot was touching down and the pedal wasn't because of the shape of the floor, push ur toes out lol! audi mate says same thing.
    Sep 2011
    Post Thanks / Like
    Just to add some experience, just had an S5 in with similar issue, apparently its wear in the clutch release bearing / or (throwout bearing if you are American), and the Audi dealer fix is a replacement clutch, which is major expense. Fine if it's warranty or goodwill but unless the clutch is faulty in other ways sticking slipping very stiff etc there is a simple fix to the starting issues. Because of the wear in the release bearing the slave cylinder is running out of travel before the clutch pedal is getting to the end stop so not trigging the engine start switch. .
    The switch has other functions and is a sealed unit, so no physical moving parts on the outside so is likely magnetically trigged by something inside the master cylinder. Anyway the fix is simply to lengthen the slave cylinder push rod so it has more piston travel. As a test I just used a small nut between the rod and the piston but later just cut and lengthened the rod by 5mm. car now starts with pedal about half inch from fully down, rather than having to press it through the bulk head like before to get it to start.
    Remember this is a get it useable fix and at some future point the clutch, (or at very least release bearing), will require replacement at kidney selling cost, so if you can get the proper fix and or it's under warranty don't mess with it but get Audi to do it free..
