Badger5JMB Retrofits
Results 1 to 8 of 8
    2,178
    1.8 Cylinder head bolts removal tool
    I need to remove the cylinder head, so need the correct tool to remove the head bolts. I just want the one tool, as I don't plan to remove any other cylinder heads, also must be 1/2" drive. I've seen one snap-on tool on ebay for just over 21, is that a good price or can I get one from halfords, eurocarparts etc?
    tux
    tux's Avatar
    May 2010
    Notts/Derbys Border
    89
    Is it the same M9/10 Polydrive (Ribe type) as the V6 engines? If yes the cheapest I could find was about 16 delivered on eBay. Didn't want to spend more than I had to as I will likely only use it on the one head job.
    If it is the polydrive type, a little tip is to tap it into the head bolts with a small hammer before trying to undo them or it slips and chews the bolt heads up really quickly.
    This is the one I think
    http://cgi.ebay.co.uk/VW-Audi-Skoda-...item335e3492fb
    If it can't be fixed with a hammer, then it must be an electrical problem
    2,178
    Quote Originally Posted by tux View Post
    That is my consern, that's why I want to make sure I get the correct one.
    tux
    tux's Avatar
    May 2010
    Notts/Derbys Border
    89
    The reason it needs tapping home, is that the bolt head, by its design has a bit of a cup effect going on and is invariably full of oil. Pushing the tool into the bolt head doesn't displace the oil and it only goes in 1/4 to 1/2 way. A gentle tap helps to squeeze out the oil and seat it fully home.
    2,178
    I Understand that, my consern is that possible **** in the bolt not just excess oil and the use of a cr@p tool & 15 years with being in the same possition = one stripped head bolt......
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,388
    AFAIK The head bolts are XZN and iirc they are 10 or 12mm.
    You'll need quite a long bit to get them all out,probably a good 6" for the deepest ones.
    http://www.justoffbase.co.uk/40-Piec...Draper-MH40-SC
    I used the longest one in that set, and had to use a bit of bodgery to get the deepest ones out.
    TD5 Land Rover Defender build
    jcb
    Sep 2005
    uk
    4,077
    unless you plan on whipping off heads all the time it is a 15-20 bit of jewelry that will sit in your tool box for the next few years.
    I have one if you just need to borrow one, not planning on removing heads anytime soon.
    works a treat and is the VAG specific one rather than a generic one
    2,178
    Thanks for that, will let you know.
