EM TuningMonster Motorsport
Results 1 to 16 of 16
    jcb
    Sep 2005
    uk
    4,070
    anyone ever lost the locking wheel stud key/adaptor?
    bloody lost mine and it turning out to be a PITA to replace.
    Audi need the car on site to try and match one of 14 possibles and then order the right one.
    trouble is I need to get the wheels off to bleed the brakes and therefore can't just drve down to Audi!!
    what are the options for removing them without a key?
    floyd 1.8 turbo's Avatar
    Mirror, Signal, Outmanoeuvre
    Apr 2008
    Bracknell, Berks
    630
    Get a socket thats only just bigger, near enough the same size as the locker then simply bash it over the locker with a club hammer, add ratchet and remove, its tried and tested!
    White B5 1.8 turbo sport
    May 2010
    194
    Yep it works, had to do this on mine when I discovered the previous owner had lost the key.
    Be wary though, I had to use a breaker bar on 3 and a big air gun on the other.
    jcb
    Sep 2005
    uk
    4,070
    I am pretty sure it won't be that tight as I have only just put the b@stard back on having refitted the subframe.
    been kicking myself since!!
    will give that a go. cheers
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,357
    if its the Audi fit locker you will need to hammer a hex key into it, IIRC i used a 13 or 14mm for my "replacement" key
    26,761
    Nearly as bad as me driving 200 miles last weekend to Lea's to do suspension, brakes etc upgrades & forgetting the poxy lock nut, got home had them of in 30 seconds flat, how much of a bummer is that huh, lol, 400 miles.
    Oh well met some of your lads aswell which is a bonus except for Voorhees seat
    jcb
    Sep 2005
    uk
    4,070
    its an Audi one, think I have some big hexs.
    cheers
    Jul 2008
    Birmingham
    629
    I hammered a 16 or 17mm socket over it. Just hit away and eventually it will start to bite. Then hit it some more till it's nice and snug and get a breaker bar on it. You will probably need four sockets though. :P
    A4 1.8TQS
    26,761
    Problem is on the ones my SB has, there is an outer ring that spins so the socket approach is useless & trying to drill into those feckers is a mission as trust me had some decent bits & didnt even touch it as such, but alas.
    Lee Goodall's Avatar
    ..got my head together!
    Oct 2007
    UK - Midlands
    2,223
    I have used these a few times with good results http://www.tooled-up.com/Product.asp...ferrer=froogle
    tazzy baby's Avatar
    Rookie
    Feb 2009
    south wales
    545
    i used one of these and it worked on my one but not sure with
    http://cgi.ebay.co.uk/LOCKING-WHEEL-...item53e2160c1f
    If you give a mouse a cookie......
    He's gonna want a glass of milk....
    vorsprung durch technik
    Oct 2006
    88
    I had the very same on my s4, used the very item Lee suggested and worked real easy
    PS may car is still for sale in the classifieds
    jcb
    Sep 2005
    uk
    4,070
    there is no outer sleeve on the OEM ones,
    that threaded one looks the business but I am not sure about the eBay one, looks a bit fragile
    jcb
    Sep 2005
    uk
    4,070
    well the 14mm hex stud worked a charm on one of them but stripped the inside out of the other,
    a 20mm socket is too small and a 21mm socket goes on too easily.
    looks like I am off to Halfrauds or some tool shop for a remover!
    26,761
    Well if all else fails could weld a nut on, make a mess of the wheel but they can always be refurbed huh.
    Also you could dremel down the edge of the last one & then get a smaller socket on it mate, worked for me.
    jcb
    Sep 2005
    uk
    4,070
    there is no space at all between the edge and the wheel for a dremmel bit without shagging the wheel.
    just going to buy one of the screw on things listed above and hope for the best
