EM TuningSky Insurance
    Jan 2004
    Northern Ireland
    34
    No dashboard illumination
    Help,
    noticed last night that I had no illumination in the 60/80mph area of the dash.
    Removed the console and moved the bulb from the oil area - everything okay
    Today I went to autoparts store and got a new bulb, not exactly same but guy to me it would be okay
    Fitted it and later as it got darker noticed I had no illumination on dash at all. All indicators, warnings lights, DIS etc work it is just the illumination
    Removed bulb and bought another from a different autoparts store but still no joy. Actually when I swapped it into the indicator, the indicator did not work
    Anyone any ideas ? I can't see a thing at night !
    The car is a 96 A4 1.8T Sport
    ps checked all fuses and they seem to be okay
    Dermot [img]/ubbthreads/images/graemlins/cry.gif[/img]
    Mar 2004
    Cheshire
    922
    Re: No dashboard illumination
    erm has it blown them all?! get a multimeter and check for continuity across each bulb to see which are naff.
    Mar 2004
    Cheshire
    922
    also do your sidelights work as if ur illumination ONLY comes on when sidelights is on, maybe a fuse is blown. Happened in my clio once when i new nothing about car electrics, did my head in!! changed fuse and worked fine.
    Jun 2003
    World of my own
    9,813
    If you used the wrong sort of bulb then you could have blown a fuse, get the right bulbs from Audi dealer
    Jan 2004
    Northern Ireland
    34
    All other lights and indicators/warning lights working, only the illumination is not
    Checked fuses and looked but replaced all those pertaining to illumination anyway ie 3, 5 and 15
    Still no joy
    Jan 2004
    Northern Ireland
    34
    Can the bulbs be purchased elsewhere ?
    I know they are Osram 12V 1.1W
    Does anyone know of an outlet ?
