JMB RetrofitsSky Insurance
Thread: s4 spring rates
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    s4 spring rates
    does any one know the spring rates or if there is a difference between the saloon and avant.
    reason being ive just got hold off a complete set of s4 suspension springs and dampers, i was only after the dampers myslef but my friend has a broken rear spring on his s4 saloon and these came of an estate , and we just wondering if there were any differences in rates etc
    also does anyone know the spring rates for the standard quattro sport suspension, because if he doesnt fit them i may put whole setup on mine as less than a third the miles mine has
    alan
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    The saloon's arse end will sit a little higher with avant rear springs, but not badly. A few people fitting RS4 suspension to their S4's noticed this.
    Mo power, mo problems
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    ye theres a tiny difference on the rear springs, but given going from old busted springs to new ones is quite likely to raise it anyway, i doubt you'll notice all that much.
    TD5 Land Rover Defender build
    "Stick a V8 in it!"
    15,370
    From memory, S4 and TQS rear springs are the same.
    Front springs are different, as the TQS doesnt have a dead horse nailed to the radiator grille
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    what about the dampers themselves? are they any stiffer etc than standard sport ones,?
    also am going to do them this morning so any advice or tips would be useful guys
    thanks
    alan
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    ok here somethign bit confusinf, we all been saying that the avant s4 had different rear springs to the saloon s4
    so i was looking as this guide to fitting and notice rear spings are paint marked 3 pink 1 white the same as i have have off the avant..........but his car in the guide is a saloon, so either the yanks got a different setup or avants/ saloon didnt nessecarily get different springs
    http://www.audiworld.com/tech/wheel28c.shtml
    http://www.audiworld.com/tech/wheel28b.shtml
    alan
