Sky InsuranceVolks Autos
Results 1 to 10 of 10
    Mar 2010
    125
    1998 S4 Avant Central Locking Problem
    Hi all,
    I recently aquired an S4 1998, and there a few issues with it, most i have sorted, but the one issue that baffles me is the central locking, and the keys.
    Basically the Central locking does not work, i out in the key and turn the clock, and it only locks the door i have the key in. The pump is connected but makes no noise at all. If i keep the key turned long enough then the windows will go down, or up depending on unlocking or locking.
    Any help is appreciated
    tony
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,357
    I would imagine the CL pump is faulty. Probably the impellar has broken up if you listen closely in the rear drives side of the boot you will probably hear it.
    Mar 2010
    125
    ok will give it a listen tomorrow, is there a place you can recomend where i get a replacement, without having to mess with codes etc, or are there other models that are compatible?
    Tony
    Apr 2004
    12,357
    PM olds_Kool on here, he does repair kits for them if thats what it is.
    Mar 2010
    125
    ok just to update, listened to it today, and it does nothing and makes no noise, took it apart, and its all intact, just out of curiosity i noticed the power connector can be connected either way so i tried this, result was, stereo started to play, but windows no longer went up or down via the key, and central locking still didnt work. I am now very confused
    Mar 2010
    125
    any ideas guys?
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,065
    if impellers intact id say you have some electrical gremlins
    where are you?
    ideally you could do with trying a different pump should be an 8L0 'G' fitted to a 98
    if you cant borrow one they usually go for 40-50 on ebay
    easy enough to sync fob if you have 2 keys
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    Jul 2007
    London
    3,079
    Quote Originally Posted by tonybolony View Post
    any ideas guys?
    I would disconect the stereo if its aftermarket as some wiring looms are shorting the k line and thats why the strange beghaviours...
    FOR SALE:
    Mar 2010
    125
    no its not an aftermarket stereo its a Bose Concert system. Looks like i will have to try another pump i guess
    Mar 2010
    125
    ideally if there is anybody living in the leeds area that would bring theres over for me to try i would appreciate it.
