Volks AutosEM Tuning
Results 1 to 8 of 8
Thread: Help required
    imported_dumpvalve
    Help required
    I noticed something dangling from under the front bumper today; some kind of plug on the end of a lead. Haven't a clue what it is or where it should go so I've managed to take two (poor quality) pictues now I'm home.
    I'm a bit worried that it should be doing a job somewhere so I'd very much appreciate somebody letting me know what it is before I set off to work tomorrow!
    imported_dumpvalve
    Re: Help required
    Here's the other pic. Off out for a few hours now (not in my car [img]/ubbthreads/images/graemlins/crazy.gif[/img]) so hopefully I will have the answer when I get back! Cheers.
    waveform2's Avatar
    * J e d i *
    Oct 2004
    Scotland
    435
    Re: Help required
    Is it for the cable for leveling of the lights? mines are dangling as my 2 peice poo lights dont have motors.
    Looks like them,
    DErek [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    imported_Yaseen
    Re: Help required
    I havent actually seen but have heard of it- it is possibly the air temperature sensor and is supposed to be there.
    check with a garage just to be sure though [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    imported_kris_tdi
    Re: Help required
    yeah almost certain that is the external air temp sensor for the DIS. it should be clipped in not dangling.
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Re: Help required
    there is a sensor that plugs into the bottom of the engine,
    best thing to do is get under it and see if you can spot an empty clip or hole.
    imported_dumpvalve
    Re: Help required
    Thanks for the help lads.
    I'll have a look in the morning and see if it clips into anything. Can't be arsed scrabbling around under the car now though.
    Cheers,
    Drew.
    imported_RastaS4
    Re: Help required
    Drew, do you have water sprays on your headlights? If yes, it might be the plug for the little motor engine for the sprayers. Just a thought! I doubt that it's the outside air temp sensor.
    G
