JMB RetrofitsEM Tuning
    Jun 2010
    76
    1.8t misfire (apu)
    hi, first post-very annoying misfire!! ive read a few other posts with similar problems but still id like to try and get a definite answer. car was checked on vag-com last week and showed an intermitant misfire on cylinder 3. theres no cel on. would this be the coilpack,maf or anything else? how can i diagnose which from which without buying all these parts? thanks for replies
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    Try swapping the coil pack from 3 into another cylinder and see if the problem moves?
    Have you replaced the spark plugs?
    TD5 Land Rover Defender build
    Jun 2010
    76
    plugs were replaced about 6k ago with gsf ones (cant remember the make). i thought of that, swapping the coilpacks but the guy will charge every time he vag-coms it! might pull the plug and check the condition
    Mar 2010
    MARGATE, KENT
    35
    I had a misfire on coil 2 a few weeks ago. had packs checked all fine, also had plugs checked all fine. made a few calls around and posted a question up on here, same answers came back, check the ignition amplifier... apparently they are rife at being faulty on the 1.8t. you can get a new one from Euro Car Parts or GSF, i got one from ECP for 67 with free p&p, delivered next day, car runs sweet now.
    Jun 2010
    76
    ive read that somewhere this morning. misfire on cylinder 2 points to the ignition amp but as said mines on cylinder 3 so i don't want to take a chance and spend 67. is there any way of testing it?
