Volks AutosMonster Motorsport
Results 1 to 7 of 7
    149
    dash has a circle with a nipple on top when i break ?help!!!!
    as above what does it mean is it discs or pads need re newing ? and it beeps when i break ?!!?
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,890
    light
    149
    break light they both work or tail light
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,890
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,350
    Perhaps you have a wrong bulb fitted?
    IE a single filament bulb installed in the brake light position, rather than the correct stop/tail bulb?
    I'd go buy two new twin filament bulbs and fit them, and see if the problem goes away.
    TD5 Land Rover Defender build
    Jul 2008
    Birmingham
    629
    When I first start mine up it does some checks and the light you described stays on till I depress the brake pedal, then it says OK. If the light remains on or comes on when you brake, as mentioned, check the bulbs.
    A4 1.8TQS
    149
    rear passenger side bulb dohh!
