dash has a circle with a nipple on top when i break ?help!!!!
theviking
as above what does it mean is it discs or pads need re newing ? and it beeps when i break ?!!?:redface:
break light they both work or tail light
Perhaps you have a wrong bulb fitted?
IE a single filament bulb installed in the brake light position, rather than the correct stop/tail bulb?
I'd go buy two new twin filament bulbs and fit them, and see if the problem goes away.
When I first start mine up it does some checks and the light you described stays on till I depress the brake pedal, then it says OK. If the light remains on or comes on when you brake, as mentioned, check the bulbs.
