Chris NottAH Fabrications
Results 1 to 8 of 8
    floyd 1.8 turbo's Avatar
    Mirror, Signal, Outmanoeuvre
    Apr 2008
    Bracknell, Berks
    630
    Exclamation URGENT HELP NEEDED! CANT GET INTO CAR, DEAD BATTERY
    As above, cars been sitting around for 2 weeks while i've been on holiday and the battery's dead. Cant get into the car, key doesn't unlock manually.
    Need to get in there before midday to take the rear seats out for the phoenix!!
    Please help!!!!!!!!!
    p.s
    I'm not a member of any recovery services, my cousin works for the RAC but might not be able to make it to my work this morning
    White B5 1.8 turbo sport
    phoenixv6quattro's Avatar
    staylowmovefast
    Sep 2009
    wycombe
    1,398
    Holy jesus! - You could try using a coathanger up through the grill to pop the bonnet release catch/cable. I did this on a saab, it works with luck on your side.....theres no rush mate ref arriving at mine....
    Ollie
    IT COULD ALWAYS BE WORSE SO KEEP ON SMILING
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    bonnet catch can be popped from underneath with a long poking thing if you jack it up, cant be done through grill that i know of
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    Apr 2008
    Bracknell, Berks
    630
    Sorted now, managed to put some jump leads onto some metal rods that i put onto the terminals through the holes in the scuttle. Put the leads onto my brothers mk3 and open sesame!!!
    Why you cant manually open the lock with the key is beyond me. How stupid!
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    Your lock must be broken/siezed as both of my cars have had working locks on the drivers door and boot, and the prefacelift has one pass side too
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,389
    On our old car, the linkage between the door barrel and the lock mechanism had snapped on the drivers door.
    There appears to be a bit of redundancy in the lock mechanism, in that when you turn the key, the barrel activates the microswitch for the locking system, and also pulls on a linkage which runs to the latch. Obviously if the battery goes dead, the key should still open the drivers door by the mechanical linkage.
    Under normal circumstances on the FWD, it would unlock perfectly fine with the key, as the central locking would be triggered and do its thing.
    As mark says though, you should have been able to get in thru the passenger door if its a pre-facelift and the boot too.
    TD5 Land Rover Defender build
    Apr 2008
    Bracknell, Berks
    630
    I could get into the boot but theres a metal bulkhead behind the rear seats so i still couldn't get into the car. I tried the key in both doors and nothing happened, tried about 5 times and nothing happened until the battery had some charge in it.
    The key normally works manually, when the battery isn't flat that is!
    "Stick a V8 in it!"
    15,389
    Linkage must be broken on both doors then! Take the door card off and have a peek.
    Central locking pump is in the boot, so you' have been able to feed some power in there etc.
