Badger5Monster Motorsport
    Audijarvis's Avatar
    Manchester
    143
    Wheel offset question
    How does the offset affect the position of the rim in relation to the hub?
    phoenixv6quattro's Avatar
    staylowmovefast
    Sep 2009
    wycombe
    1,394
    The lower the offset (et 20) the more the wheel sticks out, the higher the offset (et 48) the closer it sits inside the arch. So an et of 20 means the wheels stick out more, and et 48 means the opposite.
    IT COULD ALWAYS BE WORSE SO KEEP ON SMILING
    Audijarvis's Avatar
    Manchester
    143
    So is the off set measured from the outer rim of the wheel?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,308
    Its the distance from the centreline of the rim, to the hub mounting flange.
    Most cars have positive offset, which means the hub flange is closer to the front face of the wheel.
    Audis standard offset on the B5 is 45mm or ET45, which means the flange is 45mm closer to the front of the rim than the wheel centreline.
    TD5 Land Rover Defender build
    tux
    tux's Avatar
    May 2010
    Notts/Derbys Border
    89
    I always find this calculator helpful. Have a play and look at the results and you will soon get an idea of what offsets are all about.
    http://www.1010tires.com/WheelOffsetCalculator.asp
    If it can't be fixed with a hammer, then it must be an electrical problem
