EM TuningMonster Motorsport
Results 1 to 15 of 15
    Lee Goodall's Avatar
    ..got my head together!
    Oct 2007
    UK - Midlands
    2,223
    A4 B5 Front ABS/speed sensor.
    Does anybody have a part number for the front ABS/speed sensor for a '97 A4 B5?
    Is it just me or does VAGCAT never work anymore?!?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,909
    Vagcats been dead for a while now.
    8d0927803 is the current number.
    You got a faulty sensor?
    TD5 Land Rover Defender build
    Oct 2007
    UK - Midlands
    2,223
    Nice one. Thanks mate.
    I replaced the CV joints but one side got stuck in the hub and required a fair bit of persuasion to remove. Now I'm getting a fault code for the sensor on that wheel.. I know the reluctor ring thing is ok as it's brand new.
    It was funny because I had the traction control turned on and it kept applying the brakes at 2K revs lol.
    "Stick a V8 in it!"
    14,909
    There might be a spare laying around here somewhere.
    Oct 2007
    UK - Midlands
    2,223
    I think I'll have a go with one of these..
    http://cgi.ebay.co.uk/AUDI-A4-S4-QUA...item3efdc88eb9
    If it does the job then it's a bargain.
    "Stick a V8 in it!"
    14,909
    mind and get a new copper sleeve, your old one will probably come out in bits.
    Oct 2007
    UK - Midlands
    2,223
    There's always something!! Do you know where I can get one from?
    "Stick a V8 in it!"
    14,909
    Allgermanparts will do you one, they're about 7 quid.
    Oct 2007
    UK - Midlands
    2,223
    Threy don't seem to be featured in their online shop so I'll give them a ring when I finish work. Cheers mate.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,357
    The ones in there should be fine, they were well greased up when they were fitted so should come out intact TBH
    Oct 2007
    UK - Midlands
    2,223
    Quote Originally Posted by Byzan A4 View Post
    I love working on your old car.. anything that bolts together is greased up nicely. The top arms on the suspension (including the track rod) only took a couple of minutes to take apart
    27litres's Avatar
    Love My Quattro
    Jun 2010
    Melbourne, Australia
    20
    Quote Originally Posted by Lee Goodall View Post
    The old version of VAGCAT is rooted. Try this: VAGCATMK2
    Does anyone know how to get that ABS sensor out of the actaul hub assembly?
    I'm gonna get the wheel bearings done, but need to remove the whole hub from the car and take it to my mech's workshop for the press. They look like they'll just pull through the hollow?
    cheers
    Marty
    Marty
    jcb
    Sep 2005
    uk
    4,070
    I don't think the hole is tapered so worse case it the top come off and you pres the guts out into the bearing space
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,066
    follow the wiring it plugs in just inside inner arch, you can remove hub carrier and leave sensor in hub if you unplug it
    if you really want to remove it try twisting side to side first to loosen it
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    27litres's Avatar
    Love My Quattro
    Jun 2010
    20
    Yeah, I found that plug this arvo! Wasn't too easy on mine though - 1 glovebox removed to find wire!!
    The sensor came out of the hub easy enough, it was the carrier I was referring to when I said assembly!
    Once I knew about the plug, I realised the sensor won't fit through the hollow of the carrier!
    Cheers though
    Marty
