Chris NottJMB Retrofits
Results 1 to 10 of 10
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    Dead Pixel Repair is it this simple?
    saw this on eBay
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...E:B:SS:GB:1123
    it says
    "This manual will show you step by step how to remove the unit, fix it and replace. It should take you about 1 hour (or less).
    All you need is a screwdriver, no other tools or technical knowledge is required.
    cant be this simple can it? i do recall that on the A3 forum someone IIRC recommended to heat the DIS connections. however it had mixed reviews and experiances
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    54
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    looks informative however dont look that easy
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    Gave that a go on mine and it didn't help at all.
    Mo power, mo problems
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    which one the eBay one? or the zine?
    May 2010
    34
    i did the e-bay fix it didnt work on mine and ive got loads of dead pixels which is a bit of a pisser
    Feb 2007
    Liverpool
    1,693
    Quote Originally Posted by rasA4 View Post
    It's the same from what i've read on other forum posts. Wedge cardboard behind the ribbon cable and screen.
    calvin's Avatar
    parked up
    Oct 2007
    Sunny Sussex
    155
    fwiw I took mine to bits and tried the ebay type repair, wedging some fine strips behind the ribbon cable - it made it better, but mine also suffered from fading in heat, so in the end bit the bullet and got it replaced by Clusterrepairsuk.co.uk - for about Ł100 all in as i recall. fully functioning, guaranteed and tested..
    '98 S4 with MRC remap and gutted pre-cats - Now SOLD.
    '70 Siva Minibug beachbuggy with Supercharged 1275 A-series
    '89 VW T3 Westfalia poptop 2.1 petrol
    '52 RenaultSport Clio 172 Cup
    '52 Smart FourTwo (it is a turbo!) for when everything else is being mended...
    East Berkshire
    178
    Mine done by Cluster repair ( but it was Ł160 not about Ł100 !! )
    Again fading as it warmed up and after an hour or so you couldn't see anything + pixel problems.
    It took them 1 hr 20 mins, while I waited ( actually she spent about Ł60 in Debenhams and about Ł8 for a couple of coffees + cake..... while we waited ) and they are use to doing it.
    Reckon an hour is a bit optimisic....
    ChrisG
    phoenixv6quattro's Avatar
    staylowmovefast
    Sep 2009
    wycombe
    1,395
    HA HA HA !!! SOUNDS FAMILIAR!!!
    IT COULD ALWAYS BE WORSE SO KEEP ON SMILING
