Volks AutosMonster Motorsport
Results 1 to 11 of 11
    fallmonk's Avatar
    Turbo Sport
    Jun 2004
    Glesga,home of the rain god!
    1,836
    Heated mirrors not working?
    Can anyone help? i just noticed heated mirrors aint workin , have checked the fuse box (after a bloody hunt for the thing as AUDI say its on the left ! but its actually on the right!!) fuse aint poped so am at a stumbling block all sujestions are welcome [img]/ubbthreads/images/graemlins/froggie_red.gif[/img],
    Feb 2003
    Lincolnshire/Bournemouth
    739
    Re: Heated mirrors not working?
    I do beleive your mirror glass has overheated dear fellow.
    fallmonk's Avatar
    Turbo Sport
    Jun 2004
    1,836
    didnt know it could over heat ! ok wots my options?
    Oct 2004
    Southampton, England
    86
    if you have a multimeter couple of easy checks,
    one check the voltage supply to the glass
    two check the resistance accross the mirror glass
    normally the mirror glasses tho
    Mar 2004
    Cheshire
    922
    don't they only turn on below a certain temp?!
    Mar 2004
    Cheshire
    922
    don't know. i'm prob wrong!
    Mar 2004
    Cheshire
    922
    in my manual it just says they're only on when ignition is on! useless manual!
    imported_ronny
    They are prone to burn out, its a crap design.
    They come on when the temp goes below 5c its why there all burnt out, mine was the same, it means every time you start the car, regardless of whether there iced or fogged.
    HTH
    Ronny
    DavidR's Avatar
    Scotland
    1,295
    You can check whether they are on or off using VAG-COM, and if it says they are ON, and are not hot, the problem is clear.
    imported_kris_tdi
    i had to replace both of my ghlasses as they had burnt out.
    mine coem on with the rear heater.
    imported_kris_tdi
    got them from audi, they werent that expensive.
    just replace the glass, fairly easy to do [img]/ubbthreads/images/graemlins/smile.gif[/img]
