TDI TuningAPR Europe
Results 1 to 10 of 10
    imported_ZeroK66
    Airbag Warning Light
    hello all,
    Last night, I had a few people pile into the car - moved seats forward to accomadate the people in the back, went to drive off and noticed the airbag light come on and it has stayed on since.
    Any advice here?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    22,524
    Re: Airbag Warning Light
    You will also need to goto your local Audi stealers to get the airbag light reset with a VAG-Com.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    4,376
    Yup. Happened to mine a few months ago. My local independent tested it, came back with an intermittent high resistance fault code. They re set it, it's been fine ever since. cost £20
    Danielson's Avatar
    Jun 2004
    UK
    704
    i had this too, they reset it, it came back on, had to be replaced by the stealer, luckily it was under warranty, then it came back on again same seat airbag, had it reset been fine eversinse, wish i could say the same about the sunroof..
    Feb 2003
    Lincolnshire/Bournemouth
    740
    snoop - alcohol on the switch contacts will sort that.
    The911SC's Avatar
    Sep 2003
    South Wales - Swansea
    1,031
    you will only have done this if you have seat side airbags (which are an option I think on all except for the S4).
    There is a common problem with the airbag 'slipring' on the steering colums on B5 A4's which was covered on my old '97 under warranty..
    You will need to get the light re set with vag com and the fault registered may well be the slipring.
    Feb 2003
    740
    The911SC - all post '98 B5's actually had seat airbags as standard [img]/ubbthreads/images/graemlins/smile.gif[/img]
    imported_ZeroK66
    Mmm... so a stealer it is then. Next time I need to send the car in for suminc I will get it done then - no point in sending it in just for that.
    Thanks for all your posts guys!
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    22,524
    [ QUOTE ]
    [/ QUOTE ]
    Whilst the Airbag light is on, NONE of the airbags in the car WORK!... this may void your car insurance in the event of an accident... BEWARE...
    Mar 2004
    Cheshire
    922
    Honestly?!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    My driver's side airbag is knackered so light is on. so that means no other airbag will work!!! scary!!!
    Anyone know how much to repair? Audi or independant
