Badger5Sky Insurance
    Mar 2005
    Great Britain
    17
    1.8 t QS Rear spring broken and leaking shocks
    I have been qouted Ł107 + vat for a standard shock and Ł80 + vat for a standard spring. That's over Ł400 just to replace the rears. I am thinking I could do better, and probably replace the whole lot for not much more money. Any recommendations either for aftermarket kits or a cheaper place for standard parts please.
    I am not bothered about lowering the car!
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,521
    Jeeze, a whole set can be had for that.
    How handy are you with the spanners?
    I have a set of rear shocks and a spring you could use for a Ł60 +post
    Spring was removed fom my TQS and the shocks from a 77k S4
    Mar 2005
    Great Britain
    17
    Are the shock same from S4? If so and then the shocks are not leaking then lets get something sorted. Do you have the other rear spring?
    Apr 2004
    12,521
    Shocks are the same yes, Boge reds. No leaks with bump stops and spring seats intact. Its only the spring rates that vary on the S4.
    I only have one rear TQS genuine spring, the other snapped and i ended up changing the whole lot
    If you fancy it, PM me and we can sort you out
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    I just cut the spring to make it upto a full coil off and done the same to the other side. It depends where its broken if you can do this.
    Milton Keynes UK
    248
    Why not get a 2nd hand strut.
    saves you using a spring compressor to replace the shock.
    On my 1998 TDi the struts were not keyed so one would fit either side, not sure anout you model though.
    Try the following contact they might have one in stock.
    Overton Dismantlers
    Overton Garage Ltd
    off Dyce Drive
    Aberdeen
    Scotland AB21 0EQ
    Tel: 00.44.1224.722354
    Parts Fax: 00.44.1224.775451
    General Fax:00.44.1224.722457
    Email : sales@overtongarage.co.uk
    I think I paid about Ł40 for mine.
    Make sure you give them as much info as possible so they send the correct part.
    Regards,
    Jim.
