Monster MotorsportChris Nott
    CraigG's Avatar
    May 2008
    188
    New key, how do i change/fit a transponder?
    So i've got myself a new key on ebay. The auction says the key comes with a transponder, the invoice says it doesnt, so i'm wanting to take the front part of the key apart and see if theres a transponder in there.
    Anyone know how it comes apart?
    I've prized out the Audi rings and removed the screw, but i cant seem to get the two halves to come apart!
    I've also tried to get my head round the programming for the remote rear fob. I only have one key atm, and the remote appears to have stopped working.
    It appears i need two keys for the car to program the new fob, one for the ignition and one to lock the door? Anyone done it with one key?
    Kev
    Imola S4 - Bilstein B6 + Eibach Prokit, Anthracite BBS Pescara 18x7.5"
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    once screw is out you need to force it open, it just clips together
    remote programming can be done with vagcom otherwise you need one key to turn ign on and a second to turn drivers lock so you'llneed a second blade cutting
    if you only have one key be carefull taking transponder out, its glued in and easy to break
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    griswold's Avatar
    340
    Just had the hassle myself wih getting a spare key
    i used my swiss knife to split keyfob to get access to transponder
    You can get a keyblade cut off ebay cost me 7 del
    then that will give you the second key to program your fobs easy to do guides on here
    if you didnt get a blank transponder with your key get one off ebay 6 del
    get vag tacho for your pin/skc code and to program your new key.
    Try not to remove your transponder if its your only one, as i broke the old one getting it out unless you have to.
    A4 1.8T Quattro sport
    A6 2.4 Avant SE
