JMB RetrofitsEM Tuning
Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By CraigG
Thread: How long to complete cam-belt change
    2,152
    I was going to complete a cam-belt change this weekend, I've removed the front-end before & replaced water pumps & v-belts etc, but just wondered how long it takes to do the cam-belt, and if anyone has any tips or knows of a good write-up.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,318
    Assuming you've already stripped the front end off, the belt itself shouldnt take much longer than an hour.
    The alignment marks are completely hopeless though, and it took me a good bit of fiddling to get it all in a position i was happy with.
    TD5 Land Rover Defender build
    Jul 2008
    Birmingham
    629
    Surely you had to remove the cambelt when you changed the waterpump? I did because the oil pump pulley was in the way of some of the water pump bolts. Either way, it doesn't take long at all - the hardest part is getting the front end off.
    A4 1.8TQS
    tazzy baby's Avatar
    Rookie
    Feb 2009
    south wales
    545
    voteforpedro would you fancy giving me a hand changing mine if so how much $$$$ would you want
    If you give a mouse a cookie......
    He's gonna want a glass of milk....
    vorsprung durch technik
    Jul 2008
    Birmingham
    629
    Quote Originally Posted by tazzy baby View Post
    Sorry, I don't live in Cardiff anymore. I now live in the ****hole that is Birmingham.
    Otherwise I would help you buddy.
    A4 1.8TQS
    tazzy baby's Avatar
    Rookie
    Feb 2009
    south wales
    545
    No probs butty
    2,152
    I've not started the job yet, just looking how long it takes to do the cam-belt bit. I'm changing the water pump as well, but its going to be a job for next weekend as I'm going to do the front discs & look at the ABS kicking in just before I stop this weekend.
    CraigG's Avatar
    May 2008
    188
    Pedro, Your supposed to remove the water pump housing from the engine first, then it remove the pump from it.
    Bit of hassle, but much much less hassle than removing the timing belt!
    Imola S4 - Bilstein B6 + Eibach Prokit, Anthracite BBS Pescara 18x7.5"
    Sep 2009
    Essex
    2,366
    which engine?
    CraigG's Avatar
    May 2008
    188
    1.8T i presume?
    typertony likes this.
    2,152
    Yes 1.8T, sorry should have added that info.
    Aug 2008
    Hi! Type AudiWorld Technical Articles into your pc browser when you get there scroll down there you should find 19 pages with photgraphs step by step from removing the front to fitting the timing belt. I printed the lot of a kept it for future reference. regards Mike H
    Jul 2008
    Birmingham
    629
    Quote Originally Posted by CraigG View Post
    I was following a guide. Ah well, I did it in the end and I learnt something from the experience so it's all good. :D
    A4 1.8TQS
    Milton Keynes UK
    248
    Took me about 2 hours to do my 1998 TDi.
    No special tools required apart from decent Allen Keys that connect to a Qtr Drive ratchet. Got them from Halfords. Used to remove the bottom pulley on the Aux belt so I could take off teh cam belt.
    All I did after that was to use tipex to mark the old belt and pulleys in 2 places on the pulley. remove old belt and mark up the new belt counting the teeth.
    Put new belt on, tension and replace the aux belt.
    I removed the bumper and rad to give me more space.
    Aug 2009
    191
    i've just spent 6 hours changing all the belts today. Think they were all original audi belts on there at 129,000! they were all feked. That was going slow with lunch in between tho.
    2002 A4 AVANT 2.5 TDI QUATTRO
