Chris NottMonster Motorsport
Results 1 to 7 of 7
    imported_Yaseen
    whats a drive shaft boot? and how much to replace
    mine is torn [img]/ubbthreads/images/graemlins/frown.gif[/img], any one knows a rough price it will cost? and what does it do?
    Many Thanks
    Yaseen
    Danielson's Avatar
    Jun 2004
    UK
    704
    Re: whats a drive shaft boot? and how much to replace
    it stops the [censored] getting in there, or i guess not if its torn. not to expensive
    imported_Yaseen
    cheers mate [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    not too bad [img]/ubbthreads/images/graemlins/smile.gif[/img]
    imported_kris_tdi
    also known as cv boot, had too change both of mine for last MOT, takes quite a while as have too remove quite a lot of stuff.
    Oct 2004
    Aberdeen
    7
    i would say roughly about an hour, an hour and a half work each side, in a shop, for a trained tech. the boot repair kit...can;t remember, but affordable.
    cheers
    imported_kris_tdi
    had too remove the wheel, shock, brakes, hub.
    pain in the arse, but has to be done, nothing you cant do yourself, just requires patience.
    imported_Yaseen
    [img]/ubbthreads/images/graemlins/dancing.gif[/img]
    great news, thanks for the replies [img]/ubbthreads/images/graemlins/beerchug.gif[/img] having h&r springs/Bilstein shocks put in so will let them do it at same time.
    Then mot hassle over till next year [img]/ubbthreads/images/graemlins/smile.gif[/img]
