Badger5Volks Autos
Results 1 to 9 of 9
    2,149
    Any got this cooling part for a 1.8T
    Following on from this thread (http://www.audi-sport.net/vb/showthr...histling-noise) I found believe I found where whistling noise coming from the engine. If this is not where the noise is coming from then its a fault and need to be fixed ASAP.
    So when the engine is stopped I noticed a small amount of coolant dripping on the alternator casing, so after removing the flexible pipe I found this!
    I have removed the corroded section of pipe but I need to find a replacement ASAP, as there is none is stock at any of the North East Audi dealers and no luck with peterlee scrap yard. The part number is 058 121 071 A.
    If anyone has one of these and is willing to post please let me know, how much you want for it including P&P. Of if anyone knows of a breaker in the North East that would have one of these then could you let me know
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,287
    Cant your dealer order it in? I've never had any parts in stock when i've gone to the dealer for bits for my B5, but they've always managed to get the stuff in within a day or two.
    Also, this pipe is on the other side of the engine from the starter motor, not really sure how it could be dripping down there, unless its leaking from the plastic bit round the back of the cylinder head?
    TD5 Land Rover Defender build
    2,149
    The parts department said there is stock in Germany, so would be Wednesday before they could get one, I need the motor for work so would like one quicker than that.
    Sorry typo on the starter motor, should have said alternator.
    2,149
    Any one know if this would work, it's states for an AEB engine, but for a later year B5.
    http://cgi.ebay.co.uk/AUDI-VW-METAL-...item563ae9d6d6
    "Stick a V8 in it!"
    15,287
    I would say a tentative yes.
    You'll probably find its missing brackets or has differnt brackets for the fuel rail cover and throttle cable. The cable is routed differently on the later engines so it doesnt cross the oil filler, and as a result the fuel rail cover changed a bit.
    I've pulled all the crappy bits of plastic off my engine anyway so it wouldnt matter much to me, but it might to you.
    2,149
    Well it's a back-up plan if I have no luck over the weekend.
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    im breaking a 96 aeb?, but it wouldnt get to you till monday, can you not bodge it somehow
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    2,149
    Monday would be fine, I don't mind taking a day or 2 off work, but don't want to take 3 days as there could be further delays with Audi as I presume there parts are shipped by air!
    How much can you do the pipe + shipping for?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,500
    i would stick that one back on, push the pipe on as close/tight as i could and clamp around the very end of the pipe, lol
    Bodges R us !!
    LMAO
