AH FabricationsEM Tuning
Results 1 to 17 of 17
    imported_ZeroK66
    Speed warning... excellent!
    Was reading my manual today and found out how to setup my speed limiters/warnings, kewl man!
    Anito's Avatar
    Dec 2003
    Chester
    429
    Re: Speed warning... excellent!
    yep, got mine set @ 85mph
    Mar 2004
    Cheshire
    922
    me too [img]/ubbthreads/images/graemlins/angel.gif[/img]
    imported_lewiscsfb
    Yep, it's great. Especially in London which is full of speed cameras. I was confused at first as if you set it at say 30mph. The alarm won't go off until you reach 35mph. The warning light then remains on until the speed goes back below 30mph. So you need to set the alarm to 5mph less than when you actually want it to beep.
    May 2004
    Billericay, UK
    278
    Not in my car...
    Are you sure yours is working properly?
    Greg
    Feb 2003
    Lincolnshire/Bournemouth
    739
    I found that thing a bit annoying. I tend to use the big dial on the left of the instrument cluster, when the needle is just above the red it's time to back off [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Jun 2004
    Toronto, Ontario
    There was talk about bringing back photo radar here... if it happens I'll be turning on my speed warning!
    What's the point of it though, isn't the car electronically limited to 210km/h? [img]/ubbthreads/images/graemlins/wink.gif[/img]
    imported_ZeroK66
    lol stewart! See your in bournemouth? Are you?
    Anyway - reading the manual it goes off 5km/h after the limit you set... so yeah, you have to set it a few MPH below what you want the limit to be!
    Feb 2003
    739
    [ QUOTE ]
    [/ QUOTE ]
    Yes, I am right now.
    imported_lewiscsfb
    Reading the m-a-n-u-a-l. What is this strange thing you speak of? [img]/ubbthreads/images/graemlins/laugh.gif[/img]
    imported_ZeroK66
    Ahh... my g/f lives there, I may be down that way sometime... love the car, would love to see it in the flesh!
    Feb 2003
    739
    I guess you are referring to the silver car? That now belongs to Drew 2226, the new one is back home [img]/ubbthreads/images/graemlins/smile.gif[/img]
    imported_ZeroK66
    Ahh... okay - bummer. What is the new one?
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,673
    [ QUOTE ]
    technics100 said:
    How do you set this up?
    let me know cheers
    [/ QUOTE ]
    There's a section in the owner's manual on it. All you do is press the left-hand button inside the instrument display (the one that adjusts the clock when you pull it) at the speed you want (say 70mph), & that's it. Once your speed reaches the trigger speed, plus about 3%, a beeper goes off & the speecheck symbol comes up on the DIS. It's good reminder to keep you from what I call accidental speed drift. We all know that when you have a fast one, like a 1.8T or a 2.8V6 (that's what I have), it's easy for your speed to just ease upwards without you really noticing. This keeps you real on the roads where you can't afford to slip up (i.e. all of them!!)
    Mar 2004
    Cheshire
    922
    Yeah your fuse box is there, you have to pull the panel off on the end of it, the part which is concealed when you shut the door.
    You can set a permanent warning. This is done when the engine is off. Mine is set at 80mph so it goes off at 85mph.
    Then like has been said you can set a 2nd one by pressing the left speedo button at the speed you're travelling at.
    imported_ZeroK66
    I did read how to set the permanent warning... have to do ti with the engine off... just cant remember how lol!
    The one you set when driving is just temp - when you switch off/press the button(clock set knob) again - it clears.
    Danielson's Avatar
    Jun 2004
    UK
    704
    hey , i could do with setting the permanant speed warning, could of done with that yesterday, nevamind, how do u set it up, is 4 cars with dis only, i hope not cos mine hasnt got it, its a skinner
