Sky InsuranceEM Tuning
Thread: a4/s4
    Oct 2004
    14
    a4/s4
    hi im new to the forums and just got a 2003 audi a4 v6 quatro and i cant seem to find any turbo kits for it and i was wondering if its possible to swap a 2000 audi s4 2.7t motor into the a4??
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Re: a4/s4
    Have you had a look into the superchargers give you 295HP
    Oct 2004
    14
    Re: a4/s4
    well im looking into high horsepower so id rather have a turbo.
    imported_RastaS4
    Re: a4/s4
    Chassis is the same but I don;t know if all the necessary parts are fit to withstand that engine. Plus, you'll need to change so many items: fuel pump, clutch, fly wheel...etc! Maybe you're better off buying an S4
    G
    Oct 2004
    14
    Re: a4/s4
    well i can probably get a raceing short block so i was wondering if the manifolds and turbo made for s4 will fit the a4 and if not because of head problems then can i put the s4 heads on the a4 motor??? and i know i can get an s4 but then my insurance would shot way up so i kinda got a problem but any help would be appreciated....thanx in advance
    i also found a link to a forum in which someone said that swapping a 2000 s4 motor (2.7t) into an a4 is possible so can anyone confirm this?????
