EM TuningMonster Motorsport
Results 1 to 19 of 19
    colinurquhart's Avatar
    Jun 2009
    200
    Sorry she has to go
    Well had my beloved 1.8se avant MOT'd today and failed, nothing major
    ABS light on
    Brake pedal creeps down when held under pressure
    Front headlamps matched pair are not the same colour
    Reg light not working on offside
    Steering rack leaking and split gaiter
    Offside rear braking system leaking
    Rear wheel bearing excessive play, both sides.
    I know its nothing major, I already have a steering rack waiting, the headlight bulbs are one is standard and one has a blue tip on it. The play in rear wheels I think will be needing tightened up more as just done the rear discs and pads.
    So feeling a bit gutted found a K reg 316i lux touringon in the Autotrader and bargained it for Ł650. Only had 1 previous owner, the old guy had it for 13 years, garaged every night, and FSH and all receipts, Years MOT and 6months tax and in fantastic condition. So I'm gonna sell my audi, bit gutted but as loved driving it.
    Jul 2007
    London
    3,252
    And you drove that on a daily bassis ? Man, ABS light on might have something to do with the rear play in the bearings as the ABS rings are built into the discs or a failed ABS controller, you might also need a master cylinder or brake servo(especially if the gromets in the plenum were blocked and the servo sucked water in-results in a rusty servo and damaged brake cylinder)...
    FOR SALE:
    Jun 2009
    200
    I think when I changed my rear discs I didn't realise the abs rings were built in so didn't know to transfer them. Also think the brake pedal will be because they need bled.
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,093
    I'd sort the A4 personally but hey ho. On a K is that E30 or E36? E30 would be very cool indeed. I know a guy who drops the big 3 litre in out of the old 530, tight fit but not shy at all
    Life begins at 140mph
    www.passionford.com
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    On a K, it'll be an E30. E30's ran till L's on the Tourings...
    Shame you've lost heart with the A4 though... it's a MUCH better car then an E30 (and I've had LOADs of E30's...!)
    NEW 6 cylinder 40mm front springs - ÂŁ40
    PM me for more info
    floyd 1.8 turbo's Avatar
    Mirror, Signal, Outmanoeuvre
    Apr 2008
    Bracknell, Berks
    630
    My brother races an E30, Here it is[/IMG]
    White B5 1.8 turbo sport
    Apr 2008
    Bracknell, Berks
    630
    There it should have been! Copy and pasted the img from photobucket into the insert image thingy but still it does not work....how annoying!
    Jun 2009
    200
    Yeah its an E30 in metallic charcoal with the bbs multispokes. Although the more i think about it I might just potter away at the audi for its mot. Does anyone know if I can go to the breakers and remove the ABS ring from the rear disc and fit it into to mine as I never realised I had to swap them over until I'd chucked them out? Cheers
    phoenixv6quattro's Avatar
    staylowmovefast
    Sep 2009
    wycombe
    1,398
    I'm overhauling my rear brakes soon(front ones have been fettled with no end!), can anyone post any pics, or write a brief description/how to ref removing these "elusive" ABS rings?-And do all the B5's have them fitted?
    IT COULD ALWAYS BE WORSE SO KEEP ON SMILING
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,388
    When i did mine, i just baught a pair of new rings from the dealer. They were about Ł15 each iirc. Unfortunately they require a press to fit them, which i dont have, so I carefully filed out the centre of the ring until it would tap onto the hub with a hammer, and added some glue to keep it there.
    You can also buy brake disks with the rings fitted, my factors had both listed, but only had the non-ABS disks in stock. If i was doing it again i'd try to get a pair with the rings installed already.
    Phoenix: your car is a quattro, so the rings are built into the CV joints like the front. Its only FWD's that have this press on ring on the back of the disk, so you have nowt to worry about!
    1997 S4 - PPC ÂŁ999 Challenge Track Car Build
    TD5 Land Rover Defender build
    Jun 2009
    200
    So am i right in thinking that any set of abs rings will do, they don't need to be set up as such?
    "Stick a V8 in it!"
    15,388
    Nope just nail them on and you'll be away.
    From your failure sheet it looks like your loosing brake fluid from the rear drivers side area, which is why the pedal is creeping down, rather than a bleeding fault.
    For the wheel bearings, i tend to tighten them very gently, then get a screwdriver and use it to move the thrust washer up and down. When the preload is about right, the thrust washer becomes tight to move (not so tight you require a 12" lever to move it though). Go too far and you'll weld the bearings to the stub axle. Too loose and the bearings will wear and you'll get play, crappy handbrake and fail the MOT!
    After that all you need is a couple bulbs and the steering rack.
    Jun 2009
    200
    Cheers aragorn. Now I've had time to think I think I'll just work through my MOT sheet rather than just sell it on.
    Jun 2009
    200
    I've found a few places that sell the rings. Do the have to be pressed on as I have a fly press at work?
    "Stick a V8 in it!"
    15,388
    yer ideally they need pressed on
    mwarrey's Avatar
    Dec 2003
    Swansea
    281
    I also managed to fit rear abs rings without a press, no problem at all.
    staylowmovefast
    Sep 2009
    wycombe
    1,398
    Ahhh, thanks matey. I was wondering why I didnt come across these when I did the fronts! cheers bud! Your var is looking good by the way.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    I drifted the old ones off through the wheel bolt holes and refitted to the new discs with my 3 lb "lump press"
    Jun 2009
    200
    Well I'm saddened to say shes up for sale http://cgi.ebay.co.uk/1997-AUDI-A4-1...item35a8a9e520 as I'm not in a position to run 2 cars and fix her up.
