AH FabricationsEM Tuning
Results 1 to 11 of 11
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    snapped bonnet cable!!!!!
    just went to pull bonnet release on my new fixer upper and it went slack
    either snapped or i didnt refit properly
    how the hell do you open bonnet now
    couldve been worse car had an rs4 grill on it which i'd took off so at least i wont have to wreck that, i can see screws but dont think i can get to them
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Uh oh... I had the same problem once.
    You don't need to take the grille off. The rad is in the way anyway...
    You need to get underneath the front of the car and poke the release mechanism with a long pointy thing. You'll see what I mean when you get under there.
    As mine was so low, I had to get it up on stands first so I could get under it!
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    cheers !!! had visions of chopping bonnet up with angle grinder
    kev
    90 eunos roadster
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Yeah... I took the grille out only to find the radiator slap bang in the way. Grrrrrr!
    Once you're under the car you'll plainly see where you need to 'poke' - might help taking the bumper off to give you a bit more crawl room... it's only a 5-minute job anyway.
    PM me for more info
    Jul 2008
    Birmingham
    629
    You can pull the grill off. Mine jammed once and I just pulled the grill out. Luckily, somehow, I didn't break anything. :P
    A4 1.8TQS
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Dude... you're talking about the 'grille pop-out handle'. You can remove the grille and fix that... we're on about the interior pull handle... no fix but to crawl under the car.
    PM me for more info
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    Quote Originally Posted by olds_kool View Post
    Go on, you know you want to!
    I can't wait to get the angle grinder onto mine tomorrow!
    Unfortunately only need to grind down a couple of millimeters off a suspension arm to fit my B6 S4 rears, but angle-grinding is angle grinding!!
    Mo power, mo problems
    Jul 2008
    Birmingham
    629
    Quote Originally Posted by Geeman View Post
    My bad.
    A4 1.8TQS
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    fixed cheers, bumper was already off, i'd bent little ball cable end and as bonnet closed it was coming out
    as for angle grinder its my second favourite tool, first is a big hammer!
    kev
    90 eunos roadster
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Glad you got it sorted dude.
    PM me for more info
    Jul 2008
    Birmingham
    629
    My mate had to take a crowbar to his Cally when this happened...
    A4 1.8TQS
