Chris NottSky Insurance
    Gearbox whine and oil level
    Hi all,
    I have a 1998 a4 2.5 tdi avant (6 speed manual) and have noticed a sort of whine from the gearbox. Only really apparent in 5th and 6th. It does it both while accelarating and deccelarating, although the tone changes. If I then throttle on to get neutral revs (neither accelarating nor deccelarating) with my speed the noise stops.
    Could it be just a gearbox getting worn? 157K miles. Or needs oil? How do I check the oil level?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,379
    probably just age but worth checking the oil anyway
    On the 5 speed you undo the level plug just behind the near side driveshaft, then fashion a dipstick out of some wire. Oil level should be 7mm below the hole.
    TD5 Land Rover Defender build
