AH FabricationsEM Tuning
Results 1 to 9 of 9
    Jun 2003
    World of my own
    9,813
    Changed all brake pads and still getting warning on dash on 2.8Q
    This only happens after about 10minutes of driving, but won't clear and is getting rather annoying as it blocks out the DIS.
    Any idea's? The pads have no wiring attached to them, the only electronics is the ABS sensor. ABS light comes on as well as the brake pad warning. Never had any issues with the ABS sensors before. Does the fault need clearing with VAGCOM?
    Alex Turner
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    you sure its pad warning should be seperate from abs
    pad warning can be coded out with vagcom if thats the problem
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,344
    Pad warning has dashed brackets, ABS warning has Solid brackets round the circle.
    If its red and accompanied with three loud beeps i would imagine its ABS and not Pads. The fact it also takes a while to happen points to ABS.
    Vagcom should tell you whats going on.
    TD5 Land Rover Defender build
    Jun 2003
    World of my own
    9,813
    Yes, I thought that as well but pads were very low. They only come on together, ABS light on dash and big brake pad warning on DIS
    Alex Turner
    Jun 2003
    World of my own
    9,813
    Yes I get the 3 long beeps, will try and get it scanned. Can't understand why the low pad warning didn't come up on its own as they were dangerously low.
    Alex Turner
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    the pad warning is yellow and appears in top (radio) section of dis
    if youve got red its abs i think, is it cutting in early
    kev
    90 eunos roadster
    Jun 2003
    World of my own
    9,813
    It's not cut in since the snow
    Alex Turner
    "Stick a V8 in it!"
    15,344
    Earlier B5's dont have pad warning sensors.
    Given yours has no wiring, it probably doesnt have either.
    Jun 2003
    World of my own
    9,813
    Ahh that'll be why then, cheers
    Alex Turner
