EM TuningMonster Motorsport
Results 1 to 37 of 37
    Audijarvis's Avatar
    Manchester
    143
    Alternative wheels
    This may sound a little strange to some of you but I'd like to fit a pair of larger diameter wheels to my A4 (on 15's at the moment)
    Nothing odd about that you say
    Well as moneys tight I'm looking at picking up a set of steel rims from a breakers etc and fitting covers
    Did any A4's come with steel rims as standard?
    Which models?
    Which diameter wheels will fill out the arches without causing interference issues?
    Cars a 1.6 A4 B5 saloon
    Any other manufacturer I should be looking at?
    Jarvis
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    You might be able to fit VW van steel rims... T4/T25 or something?
    Mercedes Vito or similar...
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
    flat out
    north weald essex
    220
    surely some large merc steels will do from any of them
    Jul 2008
    Birmingham
    629
    You can get 16x7" steels fairly easily which should fit OK. Not heard of any larger than that though. Try here for ideas:
    http://fahrzeugteile.shop.ebay.de/Fe...=p3286.c0.m282
    A4 1.8TQS
    Jul 2008
    Birmingham
    629
    A4 1.8TQS
    CMD
    CMD's Avatar
    Pointing Forward's!!!!!!!!!
    Nov 2008
    S. Wales
    3,021
    Quote Originally Posted by voteforpedro View Post
    I think they are a very good Choice and cheap. Jarvis just give them a fresh coat of paint and your away.
    Jul 2008
    Birmingham
    629
    Quote Originally Posted by CMD View Post
    He may also need tyres. :P
    A4 1.8TQS
    CMD
    CMD's Avatar
    Nov 2008
    S. Wales
    3,021
    And the shipping cost...................... Back to square one, the breaker's
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,324
    if you watch ebay, you'll find sets of genuine audi 16" alloys go for 50-100quid, often with tyres.
    TD5 Land Rover Defender build
    audinary's Avatar
    Aug 2008
    Frinton-On-Sea
    646
    Not sure about Merc Commercial Vehicle rims, but I know a lot of Mercedes used a narrower wheel-bolt/stud than Audi do.
    When I fitted my AMGs I found that the bores needed drilling out from 12 to 14mm. Bear in mind also that Alloy is a lot easier to (professionally) drill than steel....
    Good luck chap. Personally, I think silver painted steels could look teh nuts. Very "scene", whatever that is
    149
    depends on the car the car they look top banana on mk 2 s with smal bumpers and skinny exhausts get some standard a4 alloys for 50 quid any day from scrap yard
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Project RS28 build
    Audijarvis's Avatar
    Manchester
    143
    A few to look at there, thanks
    Will have to take a trip to some breakers and see what they've anything suitable
    I will need a set of tires in the not to distant future so looking for cheaper (and larger diameter) wheels seemed like a way of killing two birds with one stone.
    Once again thanks for the help
    Jarvis
    Audijarvis's Avatar
    Manchester
    143
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
    Would these be suitable?
    If so please don't bid on them
    phoenixv6quattro's Avatar
    staylowmovefast
    Sep 2009
    wycombe
    1,395
    No. The PCD is wrong buddy. You need a wheel with a PCD of 5*112. Unless you are planning on buying adapters (I don't think you are, as they would completly contradict the whole point of this thread.....They cost a fortune!) DO NOT BID ON THESE WHEELS.
    IT COULD ALWAYS BE WORSE SO KEEP ON SMILING
    Audijarvis's Avatar
    Manchester
    143
    Quote Originally Posted by phoenixv6quattro View Post
    Thanks for the heads up
    Bloody minefield this wheel buying
    Audijarvis's Avatar
    Manchester
    143
    PCD 5*112?
    Is this 5 bolts at 112mm from the center of the wheel?
    Tifun's Avatar
    Highly Rated
    Sep 2009
    Indianapolis Indiana USA
    62
    yes, 5 bolts spaced at 112mm. You can also look at mk5 chassis and newer VW's for steel wheels. They share same patterns and similar offsets or "et" I'm not sure if someone mentioned that or not. Other than that while yes the mercs have the same pattern, they tend to have unfriendly offsets. So best bet is to obviously stick close to a stock et which is generally stamped on the wheel. Mercs also have a larger hub so you would need proper fitting hub centric rings as well to avoid the death wobble. While I can't say the price over there a typical set it about $15 here. I would be slightly concerned though that the steel wheel will not be able to actually hold a hub ring due to the fact that it's stamped steel verses a mold which allots for hub rigs specifically. Other than that there's not much else to it. Here's a pic of my buddy Brad who puts steelies on his B5 over the winter.
    His came off of a base Jetta 07 I think.
    Hope this helps.
    -Keith
    audinary's Avatar
    Aug 2008
    Frinton-On-Sea
    646
    Quote Originally Posted by Tifun View Post
    ... Here's a pic of my buddy Brad who puts steelies on his B5 over the winter.
    Those steelies look great, especially without the plastic trims. I wonder if a set of Crown Vic Police Intercepter dogdish hub covers would fit?
    dsmclark40v's Avatar
    Sep 2006
    Hampshire
    715
    Audijarvis a friend of mine has some of these ones if your interested.
    Those aren't actually his on ebay I just used it for the picture and he won't want that much for them. The tyres still have plenty of tread left and they are either michelin or conti sports tyres but I can't remember. He doesn't need them as the don't fit on his T5 which someone sold them to him promising they would so they are just taking up space at the moment.
    Sam,
    Gone
    Tifun's Avatar
    Highly Rated
    Sep 2009
    62
    Are you talking about the "beauty rings" ????
    http://lbcunited.com/earlyford2/index.php/cPath/135
    He had polished smoothies on them at one point.
    audinary's Avatar
    Aug 2008
    Frinton-On-Sea
    646
    Me? I'm talking about these!
    Sheriff John Bunnell might have some...
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    Later A4s have 17" steel spares. Im looking for a set but theyre hard to come by.
    Drizz Developments - Audi A4 Avant Quattro Sport
    "Stick a V8 in it!"
    15,324
    Drizz: looking at vagcat, the 17" spares are space savers and are only 4" wide.
    See here: http://www.vagcat.com/epc/cat/au/A4Q...49/54/3141828/
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    Oh yeah i forgot they were space savers lol. We're banding them when i find some more!
    Tifun's Avatar
    Highly Rated
    Sep 2009
    62
    what about newer seats and skodas??? we dont have those here but I imagine they share the same bolts patterns as well.
  28. #27
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Ideal wheels needing a refurb so should be cheapish
    http://cgi.ebay.co.uk/audi-multispok...item2c53d7bd58
    Project RS28 build
  29. #28
    "Stick a V8 in it!"
    15,324
    Those wheels fetch silly money at times.
    I paid 135 for mine, set of 5 with four duff tyres, although 4 of them had been refurbed previously, they still had kerbing etc.
  30. #29
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Exactly, only 2 days left and still at 50 bucks, i'd jump on them if i were looking for some wheels at good prices!!!
    Project RS28 build
  31. #30
    Audijarvis's Avatar
    Manchester
    143
    Took a look on the link on one of the other wheel posts on here.
    Seems there's hundreds of different wheels that will fit this model
    Have to many to choose from now lol
    Thanks all
  32. #31
    Jul 2008
    Birmingham
    629
    Quote Originally Posted by Foxmeister View Post
    Just won them for 92. :P
    A4 1.8TQS
  33. #32
    Audijarvis's Avatar
    Manchester
    143
    I got a pair of original alloys for a 1.8 turbo, with tires, for 50.
    Happy days
  34. #33
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Bit of a bargain there mate, now get a homemade funky refurb done on them and your away!!!
    Audijarvis- Happy Days!
    Project RS28 build
  35. #34
    Audijarvis's Avatar
    Manchester
    143
    Nice one!
    I'd looked at them, glad I didn't get into a bidding war with you, but to be honest I didn't want the refurbish job, and the set I got, although not perfect, are in pretty good condition.
    Maybe we should have a ebay sticky just for the B5 (someone's going to tell me there is already)
  36. #35
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,079
    I picked up my track wheels for 80 with 4 good Pirelli tyres.
    Life begins at 140mph
    www.passionford.com
  37. #36
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Quote Originally Posted by Audijarvis View Post
    Nice one!
    Yep, sure is, at the top of the b5 section under the pics thread!
    Project RS28 build
  38. #37
    Audijarvis's Avatar
    Manchester
    143
    Quote Originally Posted by Oranoco View Post
    [IMG][/IMG]
    Has everyone on this forum lowered their cars
    There's so much room between the top of the arch and the tire mine looks like Bigfoot!
