Badger5JMB Retrofits
Results 1 to 24 of 24
    phoenixv6quattro's Avatar
    staylowmovefast
    Sep 2009
    wycombe
    1,398
    A few new bits fitted.....
    Hello fellas. Got a few new bits fitted.....
    Porsche Turbo Twist Alloys.....When I got these they were in dire condition. There was kurbing and honestly about 20k worth of brake dust build up! I set about cleaning them, sanding them, painting them and finally polishing them. I then applied a few generous coats of poorboys alloy sealant to protect my hard work! All in all took me about 2 hours per wheel.......
    The cleaning/polishing stages
    Finished!
    And fitted to the car....The eagle eyed amongst you will notice I have changed the coloured centre caps for the black and silver ones. I think it looks cleaner!
    Alcantara Gaiter. I bought a small piece of Alcantara from the local fabric shop for a couple of quid and handed it over to my mother-in-law whom is an expert with a sewing machine along with the OE one to use as a template. Here is the result!
    Stubby VW OE Aerial. Got this from the local VW dealership. Reception is actually pretty good (I have tried a short RichBrook one in the past and reception was gash!!!).
    Pressed Aluminum Plates. I got thes made as plainly as possible because I think it looks a lot cleaner/smarter with just the VRN on them and NOTHING else. Spoke to a local traffic cop about them and when he saw them he said I shouldn't get pulled for them. However, They will not pass an MOT so I will simply swap them up come that time! If any of you are wondering what that oxygen sticker is for, its part of my job to carry medical oxygen. That black bit where the rear wiper used to be is a bit of carbon I have used to cover the hole....I have also de-locked the boot.
    S-Line Grill Badge. Not a massive fan of badges (It is usually completely de-badged), but took a fancy to this. Got it from the stealership. Its currently used on the 09 models. It clipped straight onto my RS4 grill! Bonus! Its staying on for now, but will probably get removed/binned when I get bored!lol!
    Custom made boot liner with a soft bit in the middle.....Just for the mutt!!
    Very happy K9....
    [IMG]http://i887.photobucket.com/albums/ac76/oliverphoenix0117/****tycamera0012.jpg[/IMG]
    ECS Magnetic sump plug. See how this is working on the next oil change.....
    Alloy Bonnet Strut. Completely pointless but why the hell not!!
    And a few OE replacement parts. Coolant expansion tank because my old one was yellow and minging! Black seatbelts because the cream ones had turned brown and I couldnt get the dirt off!! New mirror glass both sides because they were not heating up! Also got a B6 beige rear view mirror to match the colour of the interior.
    Next up I'm fitting a B7 steering wheel......This is the exact one I have just bought minus the multi function controls. Some of you might be wondering why I didnt get the flat bottomed R8 one? I do not like the chrome on the flat bottomed ones, and prefer a full size wheel...
    Also got some door levers courtesy of Byzan (thanks bud!), that I will be powder coating black and some wood trim that is currently being sprayed piano black......
    Thats all for now. Will get the pics of the wheel up next week!
    Ollie
    IT COULD ALWAYS BE WORSE SO KEEP ON SMILING
    CMD
    CMD's Avatar
    Pointing Forward's!!!!!!!!!
    Nov 2008
    S. Wales
    3,021
    Great stuff the steering wheel look's cool.
    2,178
    What are you doing about wiring the airbag in?
    staylowmovefast
    Sep 2009
    wycombe
    1,398
    I'm not. Managed to locate just the airbag cover without the internals. Was extremely cheap compared to an airbag complete, and I don't have to faf around trying to wire up a dual stage airbag......With the cover fitted it looks EXACTLY the same. The only difference is theres nothing inside! lol! Some of you disagree with not having a drivers airbag, but it really dosn't bother me. All my previous cars have had aftermarket non-airbag wheels fitted. Its never been an issue for me. Obviously, because there are no internals there is no horn-push. Already got that sorted. In the stage of wiring a horn in on the end of one of the control stalks.
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    I can see why you've got that text in your sig now... you really do spend too much time on the old girl...!
    But... I'm really liking what you're doing.
    I'm in two minds about the Porsche rims though. Think I need to see a better picture of them on the car.
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
    flat out
    north weald essex
    220
    is the steering wheel a like for like fit then as far as the ribbed section is concerned?
    does it sit well with the column shroud?
    how much was the header tank ? i might fit a new one when i fit the new temp sender.
    staylowmovefast
    Sep 2009
    wycombe
    1,398
    Yeah like for like fit. The fit is exactly the same as the my old one. As long as your cars post 98 ish it a new wheel will fit no probs. Just got to decide what you want to do ref the airbag/horn.
    Know what you mean Giles, but I got all of the above squared away in a single weekend. Recieved those spacers mate, thanks.
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Wow... that was fast... I only put them in the post at 4pm yesterday!
    The thing is though... all the mods you're doing are OEM+ which is the right way to go!
    PM me for more info
    heymynameismark's Avatar
    Cool beans.
    Sep 2009
    Aberdeen/Dundee
    126
    You should pass and MOT no problem with pressed plates. I always did. And I had short ones on the car too
    Got any better pics with the wheels on?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    Ollie, nice work mate, it's the little touches that make the car your own isn't it?
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Ollie... 20's have arrived here too. Excellent!
    How did you de-lock the boot plinth? Is it plastic on your model?
    PM me for more info
    Apr 2004
    12,523
    I soooooo want the BBS's G has...
    0% interest?
    Worth a bash,lol
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Mark... lol - PM sent. No 0% interest facilities at this end I'm afraid...!
    PM me for more info
    audinary's Avatar
    Aug 2008
    Frinton-On-Sea
    646
    Good work Ollie.
    Loving the new header tank particularly.
    Going for concours then?!
    CraigG's Avatar
    May 2008
    188
    wanna see more pics of the wheels!
    how do the 10" rears fit?
    Imola S4 - Bilstein B6 + Eibach Prokit, Anthracite BBS Pescara 18x7.5"
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    WOW you have been busy
    looking good Ollie!!! a lot of good OEM parts and the engine bay looks sweet, did you put in facelift leaf/battery cover?
    how does the magnetic sump plug work?
    how much where the belts?
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    some nice personnal touches
    need some photos showing whole car
    if you get an o.e gearknob and strip it you can give it to your talented mother in law as template and have matching knob, easy to do they just pop apart
    how much was front seatbelt, mines getting a bit slack on return
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    staylowmovefast
    Sep 2009
    wycombe
    1,398
    Hello Fellas. Yeah I know what you mean Giles. I am a big fan of keeping things as OEM as possible. Like the cheeky subtle mods (wheels aside of course, bods keep on double taking when they see Porsche wheels on an Audi!) Good, you have recieved them! Going to put the tens on at the weekend! When I said the "all squared away in a weekend" bear in mind I did get up/start work sat/sun at 4am! Works got me so busy every other weekend is all I have (MRS hates it, but ******!lol!).....
    Better pics are not possible at the moment. All I have is my iPhone so 1MP quality is all I can produce! I am in the process of getting a digital camera, and when I detail the car I will get some proper pics up!
    Ref the plates and the MOT, even better then! The facelift scuttle panel and seatbelts were obtained from Aldershot breaker yard. The scuttle was a tenner and the belts were 20 each (complete, with pre-tensioners). Very easy job fitting the new belts. 10 mins per side. The header was only 20 squid from the dealers. Well worth it IMO as I can actually see the coolant level now, and makes the engine bay look brand new! Themagnetic sump plug is supposed to catch any very small metal filings/shards/debris thats floating around in the oil. A lot of cars have them in gearboxes as standard. It was only a tenner with 10 sapre washers for oil changes so if it does turn out to be a gimmick no tears will be shed! Will post the results on the next oil change. Ref the gearknob, I have already tried(after reading about it on a thread olds kool replied to), but I wasnt very happy with the result so I have ordered the genuine alcantara/RS4 clubsport one from the dealers. Wasn't as expensive as I thought it was going to be. All I have to do when I get it(4 week wait, due to the rarity of the part)is remove the top gear indicator (I only have 5 speed) and replace it with my original one. Finally, the boot plinth was pretty straight forward. It is a metal one Giles. Very easy to remove, and all I did (got the idea from one of Stapo's old threads....) was fill in the hole with aluminum filler, sand it off and then spray it up with OE paint from the dealer.
    Soon as I get the wheel on pics will go up on this thread, and as soon as I get the digital camera I will take some good shots and get them up too. The iPhone camera is a joke!
    Ollie
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Good stuff mate, some nice changes there. Liking the pic of the pooch aswell, looks a cracker!
    Look forward to better pic of wheels, i think they'll suit it great, bit different aswell!
    Project RS28 build
    staylowmovefast
    Sep 2009
    wycombe
    1,398
    Thanks Buddy. Yeah I know the pics are crap, the digital camera should remedy that! Ref the alloys, got the insiration for them from the old RS2's. Below is a pic of one from the states running 600 hp and is probably the nicest Audi I have seen.......
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    what did you do about boot lock cylinder sticking out?, ive got a spare plinth think ill give it a go
    kev
    90 eunos roadster
    staylowmovefast
    Sep 2009
    wycombe
    1,398
    It just pulls out mate! Leaves nothing but a hole that needs filling. The boot central locking is not affected with the manual locking component removed. The only draw back is you can't open the boot with the key anymore. Mine was seized soilid (had been for 6 years according to the service history) anyway so no loss!
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    have you got the digi camera yet? if not have a look at this http://www.currys.co.uk/gbuk/panason...=369&xtor=AL-1 i got this myself last weekend well made, excellent lens and 12x optical zoom
    149
    love the porker rims didu need adapters and where did u gat grill from love it
