Volks AutosAH Fabrications
Results 1 to 7 of 7
    Daboyracer's Avatar
    Speed Freak
    Mar 2010
    Essex
    48
    Question Help Brake warning light
    Need some advice please, i've got the red brake warning light the one with ! In the middle any ideas What could be wrong? The brakes are squeaking am going to have a look at the pads at the weekend just wondered if there was anything else i should look for. The fluid level is ok. Thanks damo
    stage 5 turbo, large forge intercooler, remapped, DV, C/fibre bonnet, angel eye headlights, Lowered, front strut brace, colour coded interior with after market sport seats, 2.5k sound system, carbon fibre wing mirrors, full stainless magnex zorst sys 230bhp!!
    Jul 2007
    770
    I think thats the fluid warning.Does it stay on or do you have the three bells when starting which is an electrical fault if the fluid is ok.
    Daboyracer's Avatar
    Speed Freak
    Mar 2010
    Essex
    48
    I get the 3 bells and it keeps blinking, what sort of electric problem could it be? Would it be the sensors on the pads?
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    Abs sensor or abs module. You will need to get it on vag-com and see what it says.
    Daboyracer's Avatar
    Speed Freak
    Mar 2010
    Essex
    48
    I'll be getting the lead on monday for vag-com this sounds like it could be expensive
    mwarrey's Avatar
    Dec 2003
    Swansea
    281
    If it is the ABS ECU (quite common) you can get it repaired which will cost around 200 from someone like BBA-Reman. There are repair services on ebay which may be cheaper. (A new one is over 1000 when I last checked)
    Its not too difficult to take the ecu off yourself and send it off for repair. If you do a search on here or audiworld there are articles on how to do this.
    Daboyracer's Avatar
    Speed Freak
    Mar 2010
    Essex
    48
    would i not get the abs light come on as well if it was one of the above? hopefully when i plug it in i'll get to the bottom of this.
