Volks AutosEM Tuning
    Aug 2009
    Dorset, UK
    171
    Rear Light Cluster
    I have a crack in the offside (drivers side) rear light cluster, Have the new unit now. Does anyone know how to change these it looks quite strange design
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,917
    Remove the inner carpet or access panel cover. Remove bulb holder. Undo 4 8mm nuts (iirc) remove unit carefully releasing safety retaining clips. Should be able to do it in less than 20 minutes including a cuppa. If your new lense doesn't have the foam seal you will need to swap it over from your old unit. As Mr Haynes says "Refitment is the reverse of removal"
    Life begins at 140mph
    www.passionford.com
