AH FabricationsSky Insurance
Results 1 to 7 of 7
    Mar 2010
    MARGATE, KENT
    35
    VAGCOM code 01262
    I have recently run a scan on my audi the results came back with error code 01262 (Solenoid Valve for Boost Pressure Control (N75) 26-10 - Output Open - Intermittent)
    I have had a look and apparantly it means there is a fault with the N75 valve, this is supposed to operate the wastegate for the turbo, I have read a few diy fixes on this and some are saying to replace the loom and plug to it as it gets worn by the excess heat... any ideas?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    It might even just be the actual N75 itself. I would probably change that before condeming the wiring.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,350
    mine was the wiring
    TD5 Land Rover Defender build
    Apr 2004
    12,520
    mine was the wiring
    Would be you wouldn't it,LOL
    I know that you had that issue, i sent you the plug/wire iirc.
    I spose i could stop being lazy and look up the testing details for the n75 and wires and post here......
    "Stick a V8 in it!"
    15,350
    Mine would come and go, you could clear it and it would be fine for a few miles, then it would drop out again, other times it would drop out immediately upon clearing the codes.
    So i figured it was more likely the wires than the valve.
    staggspeed's Avatar
    staggspeed
    Sep 2009
    somerset
    56
    I had the same problem only last week,turned out to be the wires had broken just has they enter the connector to the n75,hard to see unless you pull back the sheaf on the plug.
    Mar 2010
    MARGATE, KENT
    35
    Just replaced the valve, checked wiring... all good clean and undamaged. cleared the code... went out for a run in it... checked vagcom no faults... seems to be a little less smokey too.
