    Jul 2008
    Birmingham
    629
    Any tips for installing a headlight adjustment motor?
    My O/S headlight adjustment motor wasn't connected to the housing/adjuster when I received my facelift headlights. I struggled to get the green stick with the ball on the end to sit in the hole in gap in the adjuster. I thought I had it but it's not levelling - although the motor whirrs when I adjust the lights so I assume it's working, just not "attached" correctly.
    Any tips greatly appreciated.
    A4 1.8TQS
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    They are a pain to do, connect the facelift motor to the wires and stick the dial to the highest setting, this should allow the max length poss to install it, its a case of getting the ball end to catch in the reflector so you can twist to motor in place, it's fiddly but doable. It may help if you also manually pull the lower edge of the reflector towards the back to allow max movement possible in fiddling
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    I nearly pulled my hair out with the same issue when i was doing mine, then had a moment of clarity....
    I wound the horizontal manual adjustment screw (one of the white plastic ones on the top of the headlight unit) all the way over to bring the projector unit closer to the headlight adjuster. Once i'd installed the adjuster, I just wound the manual adjustment screw back to the original position.
    Job done!!
    Mo power, mo problems
    Jul 2008
    Birmingham
    629
    Thanks for the help fellas. Will get this done on the weekend during phase 5 of fitting headlights. :P
    A4 1.8TQS
    phoenixv6quattro's Avatar
    staylowmovefast
    Sep 2009
    wycombe
    1,398
    When I put my angel eyes on I had the same problem. Its a nuisance!
    IT COULD ALWAYS BE WORSE SO KEEP ON SMILING
