Chris NottBadger5
Results 1 to 13 of 13
    Aug 2009
    Dorset, UK
    176
    High Speed Wind Noise
    At high speeds there is a bit of wind noise coming from the seals around the front doors. I had a look at all the rubbers and they all look in good condition. Can the frame at the top of the door be adjusted in some more. Or is it the catch that needs to be adjusted, the thing is the doors look like they are in perfect alinement with the rest of the car. Any idea's or is it new rubbers needed.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,379
    mines the same, i think its partly the door frame/door moving/twisting and the seals going "flat"
    You can adjust the frame by lowering the window and giving it a bit of a tug :P
    TD5 Land Rover Defender build
    heymynameismark's Avatar
    Cool beans.
    Sep 2009
    Aberdeen/Dundee
    126
    Yeah, same here. Wind noise from the driver's door at high speed. It's just the glass pressing against old seals, flattening them out and letting air pass through the gaps as far as I can tell. My Civic used to do it too
    phoenixv6quattro's Avatar
    staylowmovefast
    Sep 2009
    wycombe
    1,398
    Mines the same. Never used to do it, however I made the school boy error of pouring hot water over the windows/seals when we had all that snow a while back. It must have knackered the rubber/seals as it was always fine before!
    IT COULD ALWAYS BE WORSE SO KEEP ON SMILING
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    There was a write-up on Audi-world a while back where some guy thought the wind noise was coming from the gap where the mirror meets the window. He used a small piece of plastic hose (think it was from a fish tank) and fitted this and he said it cut the wind noise right out.
    I'll see if I can find the write-up.
    Mo power, mo problems
    Cool beans.
    Sep 2009
    Aberdeen/Dundee
    126
    Oh, really? Find find find!
    Jul 2008
    Birmingham
    629
    A4 1.8TQS
    Jul 2008
    Birmingham
    629
    A4 1.8TQS
    Jul 2008
    Birmingham
    629
    Quote Originally Posted by Blue_Thunder View Post
    http://forums.audiworld.com/showthread.php?p=2261957
    A4 1.8TQS
    Feb 2007
    Liverpool
    1,693
    http://www.audiworld.com/tech/misc.html
    Article is called - 'Fixing Wind Noise Problems' or something like that
    PW-Motorsport's Avatar
    Jun 2006
    Pembrokeshire
    389
    You can adjust the door frame correctly by removing the door card. Then loosen the 4x torx bolts on the window frame, then adjust the position of the frame in the door.
    When it is very bad you can adjust the striker place in the b post as well.
    Hope this helps......
    audinary's Avatar
    Aug 2008
    Frinton-On-Sea
    646
    The wind noise issue (which I also have) is a real license saver, prevents me going north of 110mph. Never thought there might be a cure, though.... Hmm. Sounds like a project.
    I like doing those.
    staylowmovefast
    Sep 2009
    wycombe
    1,398
    Its natures way of telling you if you to SLOW DOWN!!!!!!
