Chris NottEM Tuning
Results 1 to 19 of 19
    Jul 2008
    Birmingham
    629
    wtf did my oil go
    Oil light keeps coming on and I only changed the oil with 4.5 fresh litres about a month ago. There are no leaks and no oil in water. I checked the oil level yesterday and it was kind of low...
    A4 1.8TQS
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,914
    Oil light doesnt mean its low, it means theres no pressure.
    Fix it, or the engine will be scrap.
    TD5 Land Rover Defender build
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,691
    Knackered turbo seals causing the oil to be burnt and expelled out of the exhaust?
    Mo power, mo problems
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,358
    well, you saying you only check it once a month? Also you wont have fitted 4.5 litres in there as the capacity is a tad over 3.5 L. My best guess is you have a high ish mileage engine and its either being burnt by the engine or passing by the turbo seals in small quantities so you don't see the smoke
    Apr 2004
    12,358
    http://www.audi-sport.net/vb/showthr...engine-out-Yes
    ^^ you may need to do this to reagain pressure^^
    "Stick a V8 in it!"
    14,914
    Our old engine used about a litre every 2000miles.
    There was just enough in a 5L bottle, to do the oil change, then top the engine up for the next 5000miles and it would be on the min line when the next change happened.
    Still doesnt explain the oil light though.
    Jul 2008
    Birmingham
    629
    So... new turbo?
    A4 1.8TQS
    Apr 2004
    12,358
    if you dont sort it soon, it will be new engine AND turbo TBH
    How many miles has she done?
    "Stick a V8 in it!"
    14,914
    The oil light means the engine has no oil pressure. This is usually down to sludge and a worn oil pump.
    No (or low) oil pressure will also damage the turbo over time.
    If the oil light is genuine (ie it isnt just a faulty sensor or you having run out of oil), you will need to remove the sump and fit a new oil pump, as well as cleaning everything out.
    It might be worth trying a diesel flush before stripping it down.
    Jul 2008
    Birmingham
    629
    I did a diesel flush with the oil change last month. I will double-check oil level in an hour when I leave work. Not looking forward to removing sump, having read the other thread...
    @byzan: mileage is ~138k
    A4 1.8TQS
    Jul 2008
    Birmingham
    629
    What's the difference between 10w40 DIESEL oil and PETROL oil?
    A4 1.8TQS
    Jul 2008
    Birmingham
    629
    I remember I put a little diesel oil I had lying around while I was fast idling it with some diesel. I then drained this out and changed the oil filter. Could this be a possible cause?
    A4 1.8TQS
    Jul 2008
    Birmingham
    629
    Just been looking here:
    http://www.audi-sport.net/vb/showthr...t=oil+pressure
    and it's the DIS light, not the round speedo light, if that's worth anything.
    A4 1.8TQS
    Jul 2008
    Birmingham
    629
    Light didn't come on on drive home... I'm hella confuzzled now.
    A4 1.8TQS
    Jul 2008
    Birmingham
    629
    No light on way to work today. I am thinking it might just be the sensor then?
    A4 1.8TQS
    "Stick a V8 in it!"
    14,914
    Do yourself a favour and get a real pressure guage on there. Mine was 25quid on ebay and it gives you a much clearer picture of whats happening.
    Theres a possibility that your diesel flush has dislodged some crap, which is now blocking the pickup pipe, so it might be worth doing another change, especially if the oil has gone black already.
    Feb 2007
    Liverpool
    1,691
    Was the DIS light yellow or red?
    Yellow = Oil low
    Red = Oil Pressure
    Jul 2008
    Birmingham
    629
    Quote Originally Posted by Blue_Thunder View Post
    Yellow = Oil low
    Red = Oil Pressure
    Red mate.
    A4 1.8TQS
    "Stick a V8 in it!"
    14,914
    only immo3, 2000model year and newer cars have level sensing, so any oil warning on an earlier car is pressure!
