Volks AutosEM Tuning
Results 1 to 7 of 7
Thread: Corrosion issue
    Audijarvis's Avatar
    Manchester
    143
    Corrosion issue
    I've read several posts on here regarding this issue
    I've found the previous owner has not cleared the water from around and under the battery compartment, you all know the results
    The problem I have is that there's so much rust I cant see where the drain is suppose to be.
    Does anyone have a rust free picture of the area so I have something to work with.
    Do you think I'd get away with cleaning up the corroded area and, using fiberglass, seal the area from further damage creating a new channel to drain the water
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,389
    rust?!
    The shell is galvanised... it shouldnt be rusting!
    Ours gets choked every 6 months or so, just need to clear the crap out and its fine. One drain is directly below the battery, the other behind the brake servo.
    TD5 Land Rover Defender build
    Sep 2008
    186
    Hi,There you go..........the one under the Servo is a Bar-steward to get at..
    Think this is asked so many times it might be worth one of them things you call a Sticky..??
    http://www.aocforum.com.au/mechanica...di-a4-t233.htm
    "Stick a V8 in it!"
    15,389
    with the battery and frame thing out its not too bad!
    Audijarvis's Avatar
    Manchester
    143
    Thanks all
    Will have a look in the morning
    Got a feeling this rust may not be what it appears to be
    Please don't mention dried leaves, doh
    "Stick a V8 in it!"
    15,389
    dried leaves and sludge is all i;ve ever found down there :P
    Jul 2008
    Birmingham
    629
    The battery tray has rusted on mine but not the actual chassis. In fact I left some bare metal exposed around the wings (headlight install) for around 6 months and there is no rust! God bless galvanised chassis.
    A4 1.8TQS
